Busted the clutch cover-99zy400f
17 replies to this topic
  • MaxAZ
Posted January 13, 2009 - 08:00 AM
My clutch started to go on a rock ride and got all grabby. Next thing I know it grabbed when I wanted to slip and threw me into the side of a boulder and shoved the brake lever into the side cover. The cover might be salvagable but I'd like a better heavy duty cover since I ride a lot of rocks. I haven't been able to find anything other than stock covers for these 10 year old bikes and was wondering if anybody knew of something else out there that I can use. I did find one used stock cover on ebay for $50 but was also wondering what other models use the same cover. I'm sure the 98 & 99 YZ covers are the same but what about the WR 400s or even the 426 models. Do they all have the same side cover or are they different?
Thanks for any help.
  • matt4x4
Posted January 13, 2009 - 12:20 PM
wr/yz Clutch cover hasn't changed since 98.
  • MaxAZ
Posted January 13, 2009 - 01:57 PM
I'm thinking about buying a used clutch cover and then getting a CFC Engine Armor cover to go over it for extra protection. Are those covers any good?
  • MaxAZ
Posted January 13, 2009 - 03:04 PM
I was looking at the Boyesen Racing clutch cover in Rocky Mnt catalog and don't understand why they only list this as fitting the WR/YZ 250 & 450. If they're all the same why wouldn't they also list the 426 & 400 models?
  • bigdrtrdr
Posted January 13, 2009 - 03:10 PM
I have had one on my WR for 5 years, Works great
  • MaxAZ
Posted January 24, 2009 - 01:42 PM
I just got in a used clutch cover from a 2004 zy450f and I can tell you that it is definitely not the same as the 1999 yz400f. The hole patterns are off by over 1/2" and it is deeper so it definitely will not work. Just wanted to get this info and there and dispell any rumors that they are all the same because they aren't.
  • bigdrtrdr
Posted January 24, 2009 - 08:39 PM
You are right about the part application, But the CFC part fits all years 99-09
  • lolumad
Posted January 30, 2009 - 05:21 PM
how much did you spend on the used covers.
  • yz400fsmasher
Posted January 30, 2009 - 05:27 PM
as far as i know the 98 99 400f's are compatable with the 426 up to 02'
  • jarrah
Posted July 09, 2010 - 10:46 PM
will a 2000 wr 426 clutch fit a 2000 wr 400
Posted July 10, 2010 - 07:32 AM
No. Not even close.
  • jarrah
Posted July 11, 2010 - 02:15 PM
why ? is the 400 2000 clutch smaller or less plates than the 2000 426
Posted July 11, 2010 - 02:49 PM
The clutch is smaller overall.
  • jarrah
Posted July 11, 2010 - 10:04 PM
what is needed to fit the 426 clutch to a 400 wr EG will the clutch basket fit on to the 400 gear box main sharft is the gear the same behind basket will the 426 clutch fit inside the case I got my self a 2000 MD 426 Rekluse Z start clutch fit thinking it wood fit a 2000 MD 400wr
Posted July 12, 2010 - 06:24 AM
The 426 clutch is too large to be fit to a 400 by any practical means.
  • yz454
Posted July 12, 2010 - 08:54 AM
No they are not the same ,the 426 and up had a bigger basket.
  • jarrah
Posted July 24, 2010 - 03:08 AM
All right this is the go the 426 clutch is 6mm bigger than the 400 clutch and has 6 springs the 400 has only 5 The 426 clutch will and does fit the 400 ...then you through a z start clutch on top all is good
  • SB2
Posted August 05, 2010 - 11:46 AM
I have been trying to get a slipper clutch onto my 400 so I have tried a few different combos. The 426 clutch will fit a 400, if you also intall the clutch cover from a 426. The cover has a larger area for the basket as the 426 clutch basket is larger in diameter. I currently have a 426 cover on my 400 but am still using the 400 basket as my 03 450 basket is just different enough that it won't work without some mods done to the main shaft.
Not sure about the WR but I do know the YZ swap will work.
Glenn
Edited by SB2, August 06, 2010 - 05:15 PM.
  • On January 15, 2017
  • Hot  50 replies
  • Hot  36 replies
  • 9 replies
  • Hot  47 replies
