Bent Subframe Repair
5 replies to this topic
  • steve_97060
Posted January 10, 2009 - 04:03 PM
I bent my subframe on my 06 450 where the exhaust connects, can this be bent back without breaking? is there a preferred method, tricks, heat, slowly, etc...
any feedback appreciated...
thanks...
  • BBrown626
Posted January 10, 2009 - 05:33 PM
I heated mine with a propane torch before bending it back. My son bent the crap out of his a couple weeks ago after going over the bars 4th gear pinned. We use heat and a 4-foot black pipe. No cracking or other problems. In your case some heat and a large wrench will probably do.
Good luck.
  • pscook
Posted January 10, 2009 - 06:23 PM
That is cast alloy, so be careful. Give it a good heat soak and bend just what you need to bend. See if you can clamp the straight part in a vise and bend only the tip. If it was me, I would make a tool that attached to the big thick part to bend just that, or use my 24" Crescent wrench on it to make sure that I was bending it in the right place. Worse case scenario is that you break off the tab and end up having to weld the piece back on, but then you can make it as straight as you want.
Bend it a little at a time, not in one big shot. Keep it warm the entire time.
  • steve_97060
Posted January 11, 2009 - 02:07 PM
thanks for the info guys, much appreciated... it sounds like use heat, and bend it slowly.. kind of what I was thinking, just hope it doesn't break......
  • husqy360
Posted January 11, 2009 - 02:47 PM
ya and get it off the bike before. :thinking:
  • Wes Woodin
Posted January 12, 2009 - 08:05 PM
ditto
  • Hot  47 replies
  • Hot  50 replies
