06 WR450F Oil...
10 replies to this topic
  • GlennO87
Posted January 07, 2009 - 04:39 PM
Hey guys.
I live in Australia and i am riding in 30 to 37 degree heat most of the time.
Went to get some oil yesterday and this guy gave me BelRay Thumper 20-50w semi synthetic..............Do you guys think this oil will be ok or should i take it back seeing the reccomendation is a 10-40w?
Glenn
  • BigVthumper
Posted January 07, 2009 - 05:56 PM
mobil 1 15-50
  • tribalbc
Posted January 07, 2009 - 06:03 PM
Used it lots, works fine :thinking:
The 20/50 will actually be better for that type of heat.
  • jhmotard
Posted January 08, 2009 - 05:54 AM
i used that in my quad for 3 years until i traded it for a wr450. i used that oil for a few changes and noticed my clutch would slip a bit(adjusted correctly) so i switched to shell rotella 5w40 synthetic and i'm not looking back! especially when the belray is $9 a quart and the rotella is $18 a gallon...you do the math!
Posted January 08, 2009 - 03:23 PM
Regarding 10w40 vs. 20w-50 only, the temp range you are talking about (30˚- 37˚C) is equal to 86˚- 98˚F. In that range, either of those oil grades will work. 10w-40 is recommended for -10˚- 42˚C, and 20w-50 for from 5˚- 50˚C. I rarely ride in temperatures above 38˚C (100˚F), so technically, I never need a 20w-50 at all, but I usually use one for the three or 4 hottest months of the year anyway, when the temps are consistently over 32˚C (90˚F).
In general, a lighter oil flows better, and the oiling system works best when the rate of oil delivery and the volume delivered are higher, not when the oil itself is thicker. 40 wt is really quite adequate for a YZ450, even at 38˚C, but at that high a temperature, a 50wt flows well, and does give a little extra cushion to the ball bearings and transmission.
  • GlennO87
Posted January 08, 2009 - 07:16 PM
Ok thanks heaps hey. Its just my mechanic and th guys at the shop who are tossers anyway are like FULLY SYNTHETIC NOT SEMI SYNTHETIC.......I dont Semi will harm it for a few rides...Ill use it and go onto something else after or something?
My range of oil around here is Yamalube, Belray and Motul......Belray is the cheapest followed by Yamalube and Motul is a bit more
Shell dont hake a 10-40w here
  • Baja trail Rider
Posted January 08, 2009 - 07:26 PM
15-50 mobil 1 in 20 dirt bikes over 10 years no problems at all.
Posted January 09, 2009 - 03:59 PM
I would use the Bel-Ray or the Motul before the YamaLube. In fact, I'd use a straight 40wt before I used YamaLube.
"Semi-synthetic" in and of itself doesn't mean the oil isn't good to use any more than "synthetic" automatically makes it good (or bad). By itself, the terms mean fairly little. I know of a few syn-blends that are among the best oils you can get.
  • BigVthumper
Posted January 09, 2009 - 04:38 PM
84 VF700C mobil 1 - beat the hell out of
85 V-max mobil 1 - beat the living S#@T out of
86 cbr1000 mobil 1 - romped on
85 VF110c mobil 1 - romped on
another 85 V-max mobil 1 - beat the holly S&%T out off
03 V-max mobil 1 - Romped on more than once
06 XB12X mobil 1 - take outstanding care care of
06 WR450 mobil 1 - " "
06 Lexus mobil 1 - " "
97 4x4 F-150... 213000 miles. Same trans / engine / diff - " "
bikes get 15w50
cars get 5w40
AZ in January will get down to 30's, summer time, 120+.
  • zorroz
Posted January 10, 2009 - 03:55 PM
I ride in the aussie heat as well and have been using Motul 5100 15/50 for the last 6 years in my WR's and have never opened one up. You can buy it in 4L for $45 too! (MC mart Syd)
  • GlennO87
Posted January 10, 2009 - 10:21 PM
Yeh...Aussie...everything in Perth is more...Its like 69 here!
Ill give the Belray a go....I havnt seen Mobil bike oil here yet guys..
