hour meter quick ??
18 replies to this topic
  • ThumperKid250F
Posted January 07, 2009 - 12:46 PM
ok i just got my hourmeter and going to install it on my bike today but im just wondering if the tape they give you is strong and not going to rip off..
could i just drill and tap into my frame by the steering stem so i no it wont come off. or is that a bad idea?
  • davcon
Posted January 07, 2009 - 01:13 PM
Installed mine last nite. Used the two zip ties to attach it to the cable running on the left side near the stem. Probably a bad idea to drill the frame.
  • Wiz636
Posted January 07, 2009 - 01:15 PM
I zip-tied mine to the throttle cables on the right side of the steering head.
  • Kent Rathgeber
Posted January 07, 2009 - 01:20 PM
I drilled and tapped mine into the right side of the frame near the steering head. I do NOT trust that tape, as it used to come loose constantly, despite carefully cleaning the frame prior to applying the tape.
  • ThumperKid250F
Posted January 07, 2009 - 01:41 PM
yea thats what i was gunna do, i really dont think drilling to 1/4holes or smaller is going to hurt anything
  • William1
Posted January 07, 2009 - 02:28 PM
If the frame is 100% clean, the tape will never come off.
I made a bracket that it mounts to and it uses the front tank bolt. A company makes the same thing. Just a peice of 4mm aluminum, tapped for the meter and a hole for the mount, bent at about a 20 degree angle.
  • Justin89
Posted January 07, 2009 - 02:35 PM
I went 212hrs with mine..only used the tape:thumbsup:
  • ThumperKid250F
Posted January 07, 2009 - 09:33 PM
well i used the tape that came with it and ill see how it holds up..
btw i started the bike and it said the RMPS so i no its working but when does it start counting. its still reading at 00000.. imguessing after 10 min its going to to read 0.01 right?
Posted January 07, 2009 - 10:43 PM
After 6 minutes it should read 0.1.
  • cowboyona426
Posted January 08, 2009 - 07:48 AM
Use zip ties and tie it to the throttle cables... I wouldn't drill a hole in my frame, that part of the frame goes through quite a workout.
  • ThumperKid250F
Posted January 08, 2009 - 08:23 AM
ok thanks i only had the bike running for a couple min
  • oldmanx
Posted January 19, 2009 - 09:04 AM
I need some help. Maybe someone can tell me what I did wrong. I mounted a Yamaha meter on my WR450 last night and it doesn't appear to be working. I realize that it won't show time after just a couple of minutes of run time, but it would not show rpm's...there was no change in the display from off to running. The directions on the package said to make 4 or 5 wraps around the sparkplug wire. I made these wraps around both wires, right where they go into the connector that plugs into the spark plug/coil. Is this correct? Or do I just wrap one of the wires? If so, which one?
Thanks in advance.
  • ThumperKid250F
Posted January 19, 2009 - 09:17 AM
Thanks in advance.
I wraped my around the sparkplug boot. also did you get a TACH and HOURMETER or just a hourmeter?
  • oldmanx
Posted January 19, 2009 - 10:17 AM
Its the Yamaha hour meter...don't have the part # with me right now. I thought that it said that it displays RPMs while running and cummulative runtime when the bike is shut off.
Did you wrap around the boot where it's down inside the head or above the head?
  • Smokeslider
Posted January 19, 2009 - 10:55 AM
above the head, I purchased the yamaha meter when I bought my bike and it is just a hourmeter.
Posted January 19, 2009 - 12:32 PM
With the late model ('03 and later) YZ/WR using the coil in the plug boot, you need to wind the wire around the barrel of the coil assembly below the seal on top of the cam cover. The harness wiring above that point are low voltage, and don't produce a strong enough signal to trigger the tach/hour meter.
  • oldmanx
Posted January 19, 2009 - 12:43 PM
Thanks Gray!! Does it still require 4 - 5 wraps around the boot? Would it be best to secure the wraps with electrical tape or ?? Surely a there isn't room for a cable tie, is there?
Now I hope that I didn't cut the wire too short...
Posted January 19, 2009 - 02:45 PM
3-4 should be enough, but the more the merrier. It should stay put on its own.
If it's too short, splice on a piece of insulated solid copper the same approximate gauge, and use that. Leave the splice on the outside.
  • oldmanx
Posted January 21, 2009 - 08:43 AM
Thanks again Gray!! Once again, you were a big help. Both the YZ and WR now have functioning rpm/hour meters!!
Also, the YZ fired yesterday after about the 6th kick...after a new piston/rings and intake valve replacement...my first foray into 4 stroke maintenance. A big THANKS go to you and all those who post helpful info here.
Also a big thanks goes to my local support group...the Maz clan...even though they bleed red...
  • On January 15, 2017
  • Hot  50 replies
  • Hot  30 replies
  • Hot  47 replies
  • Hot  28 replies
