exhaust repair options
7 replies to this topic
  • Ztard
Posted January 06, 2009 - 10:48 AM
I have a 02 YZ426 and the rivet holes have been a bit mangled from repacking. 3/16th aluminum rivets were last used, and start to come loose after a few rides...other than getting larger rivets and an industrial strength rivet gun what options do I have to get this back together tight? I'd like to keep the exhaust stock if possible.
Posted January 06, 2009 - 10:58 AM
I'm going to guess that the holes in the can are beat up, but the holes in the end frames are OK. True? If so, You can cut a strip of steel to make a reinforcing band like the '06 muffler has on it. Drill holes for the rivets and snap it down over the top of the existing holes. You can drill an extra pair of holes to help hold against vibration.
Or, drill for an additional pair of rivets and substitute steel rivets with oversize heads, or drill the holes out to 1/4" and use steel rivets.
  • 426 NOOB
Posted January 06, 2009 - 06:11 PM
with a little work you could cut the exhaust can down shorter and re drill holes for endcap
  • gtxkid
Posted January 06, 2009 - 07:41 PM
Need to use high quality rivots
stainless i think
Takes a lot to break them off.
Hangglider place or some sort of aircraft supply.
Posted January 06, 2009 - 07:52 PM
Marine supplies as well.
  • 426 NOOB
Posted January 06, 2009 - 09:25 PM
also, you could tap the holes and fit them with stainless allen head bolts. Looks clean and functions very well.
  • BC3
Posted January 06, 2009 - 09:48 PM
[COLOR="Blue"]Tig weld FILL the old holes and sand off and drill new holes right next to where the originals were...I have done this and you can't tell that anything has been changed....[/COLOR]
  • Ztard
Posted January 07, 2009 - 05:44 AM
thanks to all,
  • Hot  50 replies
  • Hot  28 replies
  • Hot  30 replies
  • Hot  36 replies
  • 5 replies
