crf100f timing chain adjustment
4 replies to this topic
  • scott6058
Posted January 05, 2009 - 02:09 PM
Anyone know how to correctly adjust the timing chain on my 04 crf100f
thanks scott
  • Squidless
Posted January 05, 2009 - 04:01 PM
Are you just adjusting, or are you installing?
  • scott6058
Posted January 05, 2009 - 09:40 PM
simply adjusting
thanks for any help.
Scott
  • Squidless
Posted January 06, 2009 - 05:52 PM
I'm not an expert, but I'll take a shot at it. If I say anything wrong, the experts will correct me.
On the side of the cylinder head opposite the spark plug there's a screw held in place by a plate that is held by a bolt. When the slot of the screw is pointing up and down, the adjuster is in the middle of it's adjustment. Usually, if you turn it to the left, it tightens the timing chain and if it turns to the right, it loosens it.
With the engine running, loosen the bolt with a 10mm socket. Turn the screw to the left (ccw) until the valve noise decreases. When it's too loose, the chain goes slack as the rockers come off the cam. You are trying to eliminate this slapping of the chain and cam.
Tighten the bolt holding the plate. When it's adjusted right, you should have a high pitched whine when the engine is under load.
Anybody have anything to add?
- Brad
  • gman255
Posted January 07, 2009 - 04:08 AM
IMO, If its whining, it's a little on the tight side. Could cause premature guide ware or failure. I recommend backing it off a little.
The Clymer service manual states to make the adjustment on the head first. Personally, I adjust the at the cylinder fist. The head adjuster is a to big of a increase, for a routine maintenance. Use it when the cylinder adjustment is maxed out.
Some more info
http://www.thumperta...8766&highlight=
All the best:thumbsup:
G
CR 230F Making it Street Legal with the best Speedometer by crfer2
  • Hot  35 replies
XR100 Bog and Backfire by qwika
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • 3 replies
93 honda xr100r by Honda fanatic
  • Hot  84 replies
4-stroke 250, or 2-stroke 125? by ThatOneRider
  • Hot  29 replies
1993 Honda XR200R bearings kit/list by Jmechler192
  • 0 replies
