Should I change Sprocket bolts?
11 replies to this topic
  • jcolborn48
Posted January 02, 2009 - 04:58 PM
I have an '07 450, and am changing the sprocket, should I take this time to put on new bolts? My buddy who has the same bike sheared his bolts off, and swears that the OEM bolts are weak and need to be changed. True? Also should I use Lock-Tight when putting the sprocket back on?
  • aakmetz
Posted January 02, 2009 - 05:03 PM
bolts usually shear when they become loose, your originals should be fine, properly torqued and loctited. don't use the allen head to final tighten, tighten w/ the nut. allen heads strip out too easy. the bolt will stay as you tighten the nut.
  • 642MX
Posted January 02, 2009 - 05:24 PM
While replacing them might be cheap insurance, its not needed. Just torque them in a criss-cross pattern and use plenty of red loc-tite. And be sure to recheck them after the first ride.
  • CaptainKnobby
Posted January 02, 2009 - 06:32 PM
I allways torque mine and use the blue loctite and dont have any issues.
  • BC3
Posted January 06, 2009 - 10:03 PM
[COLOR="Blue"]Like the guys above have stated the sprocket bolts are plenty strong from the factory and won't fail UNLESS they are OVER TIGHTENED....Use a good torque wrench and BLUE lock tite (Red is a bit aggressive for bolts that might be removed again)[/COLOR]
  • Mighty_Whitey
Posted January 06, 2009 - 11:34 PM
I've got over 160 hours on my 04 race bike and close to 130 on my 06' race bike now - stock sprocket bolts and at least 10 sprockets per bike!
I've always done blue loc-tite in a criss-cross pattern and have never once had any issue at all.
MW
  • Kasjok
Posted January 06, 2009 - 11:41 PM
Also, if they don`t want to brake loose, use hot air gun and make sure to clean the threads before putting it all back together using loctite as mentioned allready.
  • Whyzee429
Posted January 07, 2009 - 06:01 PM
I've sheared some heads off my sprocket bolts. I blame it on rushing through those over-tired late nights trying to get the bike ready for the morning. I think the bolts are fine though!
  • KAS
Posted January 07, 2009 - 06:45 PM
I've never, ever used Loctite on my sprocket bolts.
And I've never had them come loose.
Come to think of it, I don't use Loctite on ANY of my fasteners, and I don't have a problem with stuff falling off.
Probably just jinxed myself huh?
Posted January 07, 2009 - 08:44 PM
Based on my experience, I don't think so.
  • trailhead2004
Posted January 08, 2009 - 02:43 PM
Yup, I'd say you're screwed now.:thinking:
trailhead
  • mazzuca21366
Posted January 10, 2009 - 02:21 PM
I never used Loctite on my bolts either. Gotta keep checking the spokes though
  • On Yesterday, 06:20 PM
  • Hot  113 replies
  • Hot  50 replies
