426 Shift Forks Bad?
3 replies to this topic
  • racerx573
Posted January 02, 2009 - 12:56 PM
On my '01 426 motor, the bike does not shift into gear right away, it always has to be rocked back and forth, or move the shifter all the way up or down, and then back up/down to the gear I was trying to shift into.
Are my forks bad, or is it something else? Shift drum? Actual gears? Don't have much experience with this motor.
  • 642MX
Posted January 02, 2009 - 04:33 PM
It could be a shift fork thats bent/worn or you could have a dog thats torn up. Your going to have to split the cases to find out, but its not a bad job.
  • BC3
Posted January 02, 2009 - 07:37 PM
[COLOR="Blue"]Sounds like you might have a broken shift mechanism
that rotates the shift drum..Easy to check it's behind the clutch hub.... [/COLOR]
Posted January 02, 2009 - 11:30 PM
Is this with the engine shut off?
  • Hot  50 replies
  • Hot  36 replies
  • 0 replies
  • Hot  47 replies
