WR Kick Starter Hard to turn open & Close
7 replies to this topic
  • TSFRANKLIN
Posted January 01, 2009 - 06:47 PM
I have a 07 WR and I have a real hard time openening the kick starter to kick start. I have oil it and it does not help. i would like to kick it more often because it cranks right up, but it is such a pain to open and close it.. Any ideas?
  • brad the best
Posted January 01, 2009 - 08:36 PM
try some wd-40 if it works then get some dry silicone lube on it or graphite lube the wd-40 will attract dirt . .
its a lot better then it being loose and rattling or flipping out .
my 03's kicker is still pretty stiff compared to a lot of bikes .
maybe there is some dirt in the pivot , you could try and take it apart and clean it .
  • KennyMc
Posted January 01, 2009 - 10:01 PM
Oh crap, that's what that thing is for. I was using it as a clothes hanger:smirk:
Sorry, as was already stated, I would use the dry silicone and check the pivot.
  • JSanfilippo
Posted January 02, 2009 - 12:35 AM
My buddy used to have a CR that was like that. Made a sound almost like two pieces of rusted out pig iron being lubed by a grain of sand :thinking:. It was annoying.
If lubing it doesn't work kick starters can be had for reasonable prices on e-bay.
  • ckroto
Posted January 02, 2009 - 07:15 AM
Not a big deal. Happened on my 07 also. Just pull the bolt, remove the kickstarter. Clean all parts and reassemble with a good quality grease. Everything goes right back to normal.:thinking:
  • WR_Dave
Posted January 02, 2009 - 08:11 AM
Just make sure you keep track of the spring and detent ball when you take it apart, they sometimes fly away never to be seen again. WR Dave
  • YamaLink
Posted January 02, 2009 - 08:14 AM
You must've been lurking in my garage when that happened to me. The silver lining in the detent ball/spring search is that the garage actually gets sorted out and I find things I lost in previous pull aparts....unfortunately I no longer own that Suzuki TE125 so this clutch collar does me no good.
  • SJMC_DON
Posted January 02, 2009 - 09:23 AM
Sometimes?!?!?! :thinking:
Anyway... this method will fix all your problems but like WR_Dave says... don't lose the spring and ball.
