I bought a '01 DR 650 SE about 3 months ago and these are the mods that have worked best for me. My bike now runs and handles WAY better than stock.
CARB 170 main
45 pilot
fuel screw 1 turn out
stock needle with 2 thin shims
stock nozzle
increase float level 2mm
choke disabled - not needed
AIR BOX - Use a utility knife with a new blade, and carefully cut open the entire top of the air box, leaving 1/2" material around the top bolt mounting locations. Extend the cuts down both sides of the air box at least 1". These extended open slots on both sides of the box will draw cool air directly from the side panel air slots. The front vertical section of the air box that is closest to the engine should remain uncut to block hot air from entering the box. Remove the back fire screen, and install a Moose air filter, which is larger than stock for better filtering and more airflow. Service the Moose filter just like a motocross bike's air filter.
EXHAUST Super Trapp "Quiet Series" muffler with 8 discs - 91db
IGNITION Install NGK CR9E spark plugs
FORKS Eibach .47kg springs - Bel Ray HVI 15wt. racing fluid 600cc in each tube - damper rod top out springs cut in half to increase travel by 3/4" - preload spacer cut to top of tube at full extension
SHOCK Eibach 7.1kg spring with adapters at top and bottom
preload - 3" of rider sag
nitrogen pressure 142 psi
compression adjuster set at 4 out
GEARING 14 tooth counter sprocket - remove stock o-ring and grind 1/8" from outside of sprocket keeper to prevent contact with chain
TIRES Maxxis M6006 50/50 tread 20 psi front 22 psi rear
GOODIES Utah Cycle woods skid plate, Renthal bars, Scott grips
e-mail me dbm14@tampabay.rr.com with any questions
Mike
DR 650 SE set up
Started by
DBM
, Jan 31 2003 02:21 PM
No replies to this topic
