Zipty Fuel Screw
12 replies to this topic
  • utvols
Posted January 31, 2003 - 06:21 AM
Has anyone tried this on their bike yet? Zip-Ty Racing
It looks like a pretty cool way to adjust your fuel screw.
  • Fryboy
Posted January 31, 2003 - 07:38 AM
Hi utvols,
I use the Kouba. See link: http://www.koubalink.../fuelscrew.html
Works great !
Fryboy
  • r1superstar
Posted January 31, 2003 - 11:54 AM
Looks good. I use a screwdriver..
  • WR250fla
Posted January 31, 2003 - 03:07 PM
I use the Zipty magnetic drain plugs in my bikes and motorhome also. I saw this fuel screw and plan to order one in a week or so.
  • WR_Dave
Posted January 31, 2003 - 05:08 PM
Mine should be here by next wednesday, now only 6 more months of winter and I can test the thing out. Just kidding ,but all you southern guys make me very jealous. WR Dave.
  • RSA210
Posted January 31, 2003 - 06:40 PM
Ditto on the Kouba T-handle.OR you can check out Motomans website,he had a cheap alternative to make your own.Hope this helps. :)
  • Marlan
Posted January 31, 2003 - 07:14 PM
Made my own cheapy out of spare parts around the shop. Used a section from an old rabbit-ear TV antenna that fit tight on the fuel screw, a wing nut, and some JB weld. Works great and only cost me my time. :)
  • bman
Posted January 31, 2003 - 07:55 PM
I just got a T-Handle mixture screw from Scotts. No drilling on anything shoved in the bottom of the float bowl. Fits perfect. For 18 bucks its very cool. I just clicked on the Scotts link at the top of TT and looked under new stuff. Best under twenty dollar thing I have ever got for my WR.
  • sabin
Posted February 01, 2003 - 01:35 AM
I made my own from locking button for cars door. It's from alumin and my fuel crew size fits perfectly inside this lock button.
Link to pictures
  • dmp437
Posted February 01, 2003 - 01:25 PM
Yes, I ordered one a while ago and got it last week. Very cool setup what with the numbers (1-4) on the screw 90 degrees apart to keep track of where you are exactly. Figure you'll never adjust it more than a half a turn to compensate for anything. Knurled surface for an easier grip, these carbs should come with the easy adjust screw already on it. You transfer your spring, washer, and rubber O-ring from your original pilot screw to the ZipTy unit and screw it in. I lost the rubber O-ring during the switch and had to order some extras up from Sudco.
  • ddialogue
Posted February 02, 2003 - 03:17 PM
I have one of these on order. Are you still able to rotate the carb with the handle in place? I had a Kouba t-hanlde on my 02 WR426 and I had to take the screw out each time I wanted to work on the carb because it would not clear the cam chain tension bolt on the back of the cylinder when it was rotated.
  • The_Blue_One
Posted February 07, 2003 - 01:29 PM
Just got mine and it is low profile enough to rotate the carb.With the electric start it was a real pain to try and get a screw driver in there i'll link a pic when i get home.
  • blackie
Posted February 07, 2003 - 02:55 PM
I just got my Zip-Ty fuel screw today and installed it. No electric start on the YZ, just the hot start that made it difficult to rotate the carb. Now that it is installed, I can say that it is very cool! It is very easy to adjust while the engine is running and like Dave said, the numbers are great for a reference.
John
