drz400sm gearing???
30 replies to this topic
  • MxGene55
Posted December 30, 2008 - 10:30 AM
I have a 05 sm and now I'm running 16-41 gearing but when I go on the hiway too much rpm for me. I would like to us a 38 or 36 rear sprocket, has any one used them? whats better for 65 to 75 rpm? and where can I get one? thanks Gene
  • Regalman
Posted December 30, 2008 - 10:48 AM
If you go much higher its gonna be a turd off the line. Many have here have tried, but I think a lot switch back. [Unless of course you have a big motor]
  • kman780
Posted December 30, 2008 - 12:33 PM
At 75 the DRZ will be buzzy no matter what. Its not a cruiser....
You will not hurt anything just have to get used to it. You should hear my S with 14/47 going 75..... :busted:
  • DRZ400Senior
Posted December 30, 2008 - 12:48 PM
Doing a 38t rear is very common for the freeway riders.
  • smrookie
Posted December 30, 2008 - 01:02 PM
15-41 is the sm stock gearing.
16-41 or 15-39 is a good highway gearing. Those combination is a good compromise for street & highway use.
Anything lower will make your low end torque suffer.:busted:
  • Regalman
Posted December 30, 2008 - 01:14 PM
Keep in mind guys... he already has the 16 up front. Yes, many guys opt for a 38 rear, but I don't think a lot mix that with the 16 up front also. [Even greg, the 'king of mpg's and milk crates' felt that gearing was too high.]
  • mickeydee
Posted December 30, 2008 - 01:15 PM
the drz likes to rev.im running 15/38 and it good for riding with my sportbike buddies but when i get into town its no fun.
  • cal_tony
Posted December 30, 2008 - 07:43 PM
I have a stock DRZ sm with nothing more than than a Ti muffler sys and the JD carb kit.
Right now I'm running 16-38. Best setup I've had so far. I've always been a tall gear man, so it's perfect for me. It's not like me criticize other riders, but for those who complain about a tall rear sprocket(36-38) they need to get in the habit of using 1st, 2nd and 3rd a little more. With the old stock SM gearing, first and second was something I used from a dead stop and nothing else. With my gearing, I use everything including 1st for a 30-35mph corner.
Yeah, with a 38 in the back, you can't cruise at 50-55 in 5th anymore. But, what's wrong with using 4th? For those complaining about around town riding, what's wrong with using 1st or second. I can wind second to 55 mph.
3rd gear will wind to 75mph, 4th to over 85, and believe it or not I can cruise all day long on a level road at 90 mph in 5th.
What more do you need to know?
The bike doesn't seem to struggle at all as long as I'm in the right gear. But, you do have to be in the right gear. Previously, I had thought about a 440 kit and a carb and when my extended warranty runs out, I probably will do those things. But, it won't be because I feel the current configuration is underpowered.
Tony
  • mickeydee
Posted December 30, 2008 - 09:53 PM
The bike doesn't seem to struggle at all as long as I'm in the right gear. But, you do have to be in the right gear. Previously, I had thought about a 440 kit and a carb and when my extended warranty runs out, I probably will do those things. But, it won't be because I feel the current configuration is underpowered.Tony
once you put on a fcr and a 440 kit you'll realize how much your bike is underpowered with that gearing and a basically stock motor
  • captainkevlon
Posted December 31, 2008 - 03:00 AM
I've run 41t rear and 16t front for 18 months, mainly on the freeway, in conjunction with 3x3, Dynajet and straight thru system......
I found it great, but, having watched this forum I see that some guys are running 38 or 39 rear with the 16 front.....so I grabbed a 39t from Talon here in England and stuck that on.......wow...even better now !
No loss of accelleration, but you feel like you get another gear at the top end....and calmer freeway rpms....(still wheelies dandy tho)
My son has the same bike, and was running 16 front and 41 rear....we had a tear-up and were neck and neck until I stuck it in my new 5th gear...then it was ta-ta slow boy...he's changing to 39 too now
Take note though, we're both about 12 stone (168lbs) in our gear....heavier riders may not get the same result
Hapy New Year Alll
K
  • YZEtc
Posted December 31, 2008 - 05:22 AM
Sounds like you're just gonna' have to try if for yourself and see if it does it for you.
My opinion is that stock, the bike really needs a 6th gear unless you never cruise faster than 65mph.
Sure, the bike will go faster than that, but to me, doing it for miles on end makes me realize that the overall ratio is a bit too low.
On the other hand, I see no point in gearing it so tall that you're basically hoping to have the bike idling down the freeway at 75mph and having big gaps from gear to gear.
When you're sport riding, that can be annoying, too.
What I have used is a stock 15-tooth up front and 38-tooth and a 39-tooth rear sprockets.
The rear sprockets came from Sprocket Specialists.
I'm currently using the 39-tooth rear, and for me, this is the best compromise.
I feel that there is no ideal solution because the bike isn't a 6-speed and it's only a 400 (which is considered a pretty small-displacing street bike these days).
  • clrwatrtom
Posted December 31, 2008 - 05:30 AM
where do you find smaller rear sprokets and a 16 t counter sprocket here in the U.S.? i've been shopping for sprockets and can't find anything smaller than 41 or larger than 15
  • Regalman
Posted December 31, 2008 - 05:31 AM
Yeah, but you still have to get moving. Heck, I thought it was a bit annoying taking off from a redlight with 16-41... I can't imagine how much more it would suck with 16-38... you must be dang near required to slip the clutch when taking off.
  • captainkevlon
Posted December 31, 2008 - 05:39 AM
not at all regalman
16/39...still tears off the lights like a bat outta hell
and still wheelies in 1st and 2nd no probs
what do you weigh ?
K
PS Talon do both 39 and 16 here in England, I'm sure they'll ship to the States if needed
  • Regalman
Posted December 31, 2008 - 05:42 AM
Oh... about 17 stone. :busted:
  • captainkevlon
Posted December 31, 2008 - 05:53 AM
ah......therein lies the answer :busted:
  • kman780
Posted December 31, 2008 - 05:55 AM
LOL I guess we can add how much do you weigh to the listy of questions that get classic regalman wise ass answers.
Someone start an oil thread now or a loud pipes argument...
  • Regalman
Posted December 31, 2008 - 06:30 AM
It's just a beer gut... admit it, you're jealous. :busted:
  • kman780
Posted December 31, 2008 - 07:20 AM
It's just a beer gut... admit it, you're jealous. :moon:
Looks about 19 stone to me.... :busted:
  • cal_tony
Posted December 31, 2008 - 08:33 AM
not at all regalman
Good thought about the Talons. I've been to the Talon site a number but have been unable to find anything on the site about ordering anything. They carry sprockets for my GasGas enduro and would love to get a few of them.
The only place I found so far was R&T Trials and they carried the trials sprockets only.
Tony
Suzuki DR-Z400S 2017 by Chris.GVS
  • 0 reviews
Drz400E aus spec E and mrd exhaust by GearHeadGumbie
  • 0 replies
gearing up for the TAT by Jonny Black
  • Hot  47 replies
Upgrading from S to SM forks and rear axle worth it? by arpuS
  • Hot  50 replies
DRZ to become Adv bike, what bike for DS & singletrack? by BlueHeart
  • Hot  56 replies
