2007 wr450f gear shift
3 replies to this topic
  • zoezie
Posted December 29, 2008 - 09:32 AM
WR450F (2007)
Gear shift lever is rubbing against casing. I can not remenber dropping the bike on this side to cause the lever to bend.
How far from thr case should the lever be?
Thanks in advance
  • Powerage
Posted December 30, 2008 - 12:21 AM
Mine was rubbing a bit from new, but there is a fair bit of room on the gear spline to move it out a little.
Play with it a bit after you've moved it out a bit, cuz even when i thought mine was out far enough, there is still a little bit of flex in the lever and it can bend in a little as you're coming up with your foot and still scratch the cover.
Personal preference really as to where you want the leaver, just try a leave part of the spine sticking through the lever clamp, just to be safe.
Cheers :busted:
  • zoezie
Posted December 30, 2008 - 08:12 AM
Cheers :busted:
Thanks for your advice, I shall give it a go.
  • vomitbomb
Posted January 19, 2009 - 07:43 PM
Just had the same thing happen and the lever was hard to use and kept digging into the casing..
I just went to the shop and looked at the new bikes, just under 1cm from the casing. I just put mine in a vice and bent it back slightly using a pole for leverage.
