cheap horsepower for 06 yz450
20 replies to this topic
  • mattyd1977
Posted December 29, 2008 - 04:58 AM
Hi team
Does anyone know how to get a little extra horsepower out of a 450 without spending a fortune on exhausts, head work etc, any help and tips appreciated.
Matt
  • almostinvincible119
Posted December 29, 2008 - 06:01 AM
eBay. Look for deals. There's no such thing as cheap hp. Plus your on a fo fiddy. Try changing the gearing, you may find out that doing so is more helpful than pluggin hp
  • qwik12beat
Posted December 29, 2008 - 06:40 AM
^^^true that man. I just fitted a 51tooth sprocket, and the bike is much more ridable to me. I just pin it everywhere now:thumbsup:
When i had my stock exhaust i shortened it 3 1/2" and it made it rev alot harder.
  • BC3
Posted December 29, 2008 - 07:15 AM
[COLOR="Blue"]Jet it for your elevation and it will be a different motorcycle.........Pretty CHEAP HP...[/COLOR]
  • Wiz636
Posted December 29, 2008 - 09:55 AM
The '06 has an awesome motor....smooth, linear, and powerful. I can't think of any inexpensive way to improve it other than making sure you are jetted correctly.
In all my time on my '06 I can think of only one instance where I wanted more HP and that was in a race that had a 1/2 mile long silt bed that was 5th gear WOT...but I was running 14/48 gearing. With stock gearing it would have been fine.
  • atropine
Posted December 29, 2008 - 10:56 AM
What is your definition of cheap? I spent $200 on a 13.5:1 CP piston, installed it myself so no labor costs. I couldn't believe the improvement. I also spent $100 on the Zip-Ty carb mod at the same time, but I think the majority of the power gains are due to the piston. This bike is incredibly fast now.
  • NortonMoto
Posted December 29, 2008 - 07:01 PM
Question, Does your engine run good on 91 octane with 13.5:1 CP piston?
  • husqy360
Posted December 30, 2008 - 12:50 AM
hot cam kit on ebay only 250 for both.
http://cgi.ebay.com/...sspagenameZWD1V
  • mattyd1977
Posted December 30, 2008 - 05:12 AM
Zip ty carb mod?, I have also lopped off 5 inches to help it breathe easier, Im also going to throw a 51 tooth on it as well, it has a 49 at the moment, thanks for all the help everyone, matt
  • atropine
Posted December 30, 2008 - 08:24 AM
I have only run about 5 tanks of gas through it since I put in the piston. The first 4 were 100 octane just to be safe, but everyone has told me that I should be fine with 91. So I ran a full tank of 91 on a 4-hour ride a few days ago, and I didn't notice any difference. It ran great on 91. The low-end power increases are very impressive. I forgot to add the cost of new gaskets; another $30 or so...
In answer to the other question, the zip-ty carb mod involved pulling the carb out and sending it in to zip-ty racing. They do some modification to it to sharpen the throttle response and remove the low-end bog. There is a lot of discussion about it here on the forum.
  • turbod
Posted January 01, 2009 - 06:55 PM
Hi guys...looking at a 06 yz 450, does the 06 have a manual cam chain adjuster or the auto ? Thnx
  • atropine
Posted January 01, 2009 - 07:13 PM
I guess you would call it auto-- you just bolt it in and forget about it.
Posted January 01, 2009 - 10:34 PM
Completely automatic, and an excellent design.
  • turbod
Posted January 02, 2009 - 05:04 PM
ok cool..sounds like good design from yamaha. Heard about 06 rmz having a manual cam chain adjuster also having to split the cases to get at the oil filter screen . Thnx for your help ! You guys know your stuff ! Im learning .
  • CaptainKnobby
Posted January 02, 2009 - 06:39 PM
I done the 1/4 turn throttle mod to mine and it only costed me about $2.50 and that was for only the glue and pvc coupler.
With this mod it tricks your brain thinking you gave your bike more horse power but in reality your just not having to bring the throttle all the way back to get it to WOT!!! ... just a quarter turn.
  • Justin89
Posted January 02, 2009 - 07:10 PM
For me: Proper jetting and I lost 15lbs at the gym:moon: :smirk: :thinking:
Posted January 02, 2009 - 11:35 PM
Heard about 06 rmz ...having to split the cases to get at the oil filter screen .
The sump screen in most bikes is accessed that way. The oil filter is another matter.
  • FinchFan194
Posted January 03, 2009 - 05:18 PM
LOL I could stand to lose 15-20lbs also, now that is cheap horsepower. I am glad someone said it!
  • WR450FGreg
Posted January 04, 2009 - 01:09 AM
I did the "1/4 turn throttle mod" to my '08 WR450F this afternoon.
Instead of using PVC pipe I turned up a 3mm thick spacer from nylon stock and cut it to fit.
Not sure about the YZ, but the '08 WR needs to have it's throttle cables modified for this to work. I had to trim 5mm off the end of each outer, ie. the tip of the bent plastic guide. Without this the enlarged section of the throttle won't slip past end of the cable outers.
Took it for a run on the road (it's currently in motard form) and I must say I was impressed with the feel of it. The bike felt faster.
I'm due to go trail riding next weekend on it, can't wait to see how it goes/feels in the dirt!
Greg
  • motox-senior
Posted January 10, 2009 - 11:53 AM
try running ras gas
  • Hot  47 replies
  • Hot  28 replies
  • Hot  36 replies
  • Hot  30 replies
