broken bolt
1 reply to this topic
  • Sweet_on_my_WR__426
Posted July 12, 2002 - 11:35 AM
Not a bright move on my part, but I overtightned the bolt that snugs the kick start lever to the shaft and it broke off inside the lever(threads)?
Does anyone have a tip on removing whats left of the bolt?
  • Hick
Posted July 12, 2002 - 11:45 AM
Click Here
The easy answer is use a bolt extractor, but if you break THAT off in there you are doomed.
This is what I would do:
Buy the largest extractor that will clear the bolt hole. Remove the side cover and use a drill press to ensure the hole is centered. Thread the extractor in, and CAREFULLY attempt to dislodge the bolt.
You may spray with solvent and/or lubricant, any help you can get.
Sorry, but hope this helps.
