new rebuild, coolant leak, can't figure it out
1 reply to this topic
  • HartsYZ450
Posted December 28, 2008 - 11:27 AM
this is an 03, 450. just rebuilt it from the crankshaft up. it runs ok, untill it warms up, then coolant starts leaking out the weephole below the waterpump. put new seals in , and the shaft is realatively new. flow passage seem clear when blowing through all waterjackets, and radiators.
what am i missing?
  • qwik12beat
Posted December 28, 2008 - 12:00 PM
Replace the inner/outer seals,impeller shaft, and the bearing. Your bearing is probably ol and worn letting the shaft move around, and destroying your seals. Just had the same problem:thumbsup:
  • 0 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  79 replies
  • Hot  36 replies
