How do I tell if my YZ426 is an 00, 01 or 02 model?
13 replies to this topic
  • Brett1981
Posted December 27, 2008 - 09:59 PM
I bought a bike from an old mate of mine who said my YZ426 was an 02' model. I downloaded the manual and the clutch looked very different to what I have, and then found out it had a YZ400 back wheel on it. All things say it has an 2000 model 426 clutch and carby so to me that must mean it is a 2000 model? How else can I tell does anyone have any tips?
  • MX1967
Posted December 27, 2008 - 10:29 PM
Look at the serial number on the frame behind the front numberplate & count 8 numbers back..that will show you the year model. Also, I remember my 02 426 was the first year to have the newer style front hub, fatter than the 01 & older years.
Posted December 28, 2008 - 09:40 AM
10 characters. The TENTH character of the VIN code is the year model, not the eighth. A "Y" is the year 2000, '01 and '02 are the characters 1 and 2, respectively.
The 4th through eighth characters are vehicle info (model, equipment)
  • GENE426
Posted December 28, 2008 - 09:51 AM
also a 02 has a non painted Aluminum sub frame as opposed to the blue on an 01 and older
  • Brett1981
Posted December 28, 2008 - 03:19 PM
Ok thanks for your help, here's a challenge, it has a blue painted subframe, 2000 model clutch with the frame number: JYACH01C8WA005556 and is in Australia.
So WA00 is the 8th from the back and 10th from the front, does this say 2000 model?
  • TIG88
Posted December 28, 2008 - 03:58 PM
You have a 1998 YZ400. The W was the 1998 year character.
  • canute
Posted December 28, 2008 - 04:35 PM
Also explains .. "found out it had a YZ400 back wheel on it".....yz400 rear wheels are not interchangeable :busted:
Posted December 28, 2008 - 07:42 PM
,99 is interchangeable, '98 is not.
http://www.thumperta...ad.php?t=632582
  • MX1967
Posted December 28, 2008 - 07:54 PM
I said count 8 numbers BACK...which means from the end on the vin
  • Brett1981
Posted January 02, 2009 - 09:43 PM
Ok that means I got ripped by a friend who said it was an 02' YZ426 :-(
I have investigated a bit though and definitely measured a 426 piston, it has a 426 carby as well! Does that mean someone modified converted a YZ400 if that is possible? Is there any other explanation to this? Thanks for all your help
  • The Italian Stallion
Posted January 03, 2009 - 04:42 PM
If it does have stock graf and they are in reasonable shape it will say titainium 5 valve on the bottom of the side pannels if the bike is an 01 or 02 426
  • JoeyHellBent
Posted September 28, 2012 - 06:48 PM
Top valve cover should read 5 valve, the 400s were only 4v I have a 2000 with an almost identical vin WA00 mine is a 2000. Easiest way tot tell differance between the 3 years was 00 had a blue steel sub frame 01 had a blue aluminum and 02 had a raw finished aluminum.
  • JoeyHellBent
Posted September 28, 2012 - 06:49 PM
"five valve" will be on the right side rear on top of the valve cover.
Posted September 29, 2012 - 08:04 AM
Not true. All YZF's except the '10+ YZ450F are 5 valve engines.
This is also a 3 year old thread.
  • Hot  30 replies
  • Hot  113 replies
  • Hot  38 replies
  • Hot  50 replies
