08 yz450 PMB Spark Arrestor Pics
4 replies to this topic
  • davcon
Posted December 27, 2008 - 03:49 PM
Installed today. Now I'm legal! Didnt see any pics with it on a bike when I was looking to buy. Hope this helps others. Used a drill press with a step bit to drill out the existing rivets. Used a vice to remove the stock end tip. Used a hand drill for the new pop rivets. Easy install. Sounds and looks good.
  • Wiz636
Posted December 27, 2008 - 05:31 PM
Looks good, thanks for posting the pics. Notice any power loss or sound reduction?
  • tribalbc
Posted December 27, 2008 - 06:21 PM
I have one on my 08 YZ exhaust on my 07 WR. I found power output to be about the same with a different sound but similar DB noise. Test around 97-98db. I run mine with the silent insert to pass the 96db at races. Come in just under 96. Silent insert seems to smooth the power out a bit with maybe a small loss.
  • tribalbc
Posted December 27, 2008 - 08:29 PM
One thing to add. That shot is from June. The andonizing on the endcap is now a dull grey. No biggy if you don't worry about the bling factor. I only clean with straight water so I figure it is either from heat from the exhaust or our mud is really acidic ??:busted:
  • davcon
Posted December 28, 2008 - 07:16 AM
Havent had a chance to ride, just idle in the driveway. Its not louder but did notice a "flutter" sound at low rpms. tribalbc said it well " different sound but similar DB noise"
  • 10 replies
  • Hot  113 replies
  • Hot  36 replies
  • 0 replies
