wr 450 hp
2 replies to this topic
  • giiil
Posted December 25, 2008 - 12:25 AM
Hello,
I am thinking about buying a 08 wr 450. I owned a yzf 426 and i am wondering how does a wr 450 (free mods done + yzf complete exhaust) compare with yzf 426 power wise?
I am hopping to get 2 or 3 hp more out of the wr to compensate for the additional weight.
  • brad the best
Posted December 25, 2008 - 10:48 AM
definitely more power then the 426 , are you planning to do the cam's to ?
02 yz426-231.5 pounds dry
08 wr450-248.0 pounds dry
i can't find actual hp numbers but if you put a set of cam's in the 450 and all the free mods with a pipe i guarantee it will spank a 426 , i wouldn't even worry about the cams , but its an easy option .
the alluminum frames are a lot better mannered bikes you won't regret it .
just don't freak out when you drive a corked wr , i know i wondered why the throttle didn't move and figured a 450 should be doing a little more then a 250 .
  • tweav
Posted December 25, 2008 - 08:05 PM
my 07 wr450 with all the free mods and a fmf pipe and mega bomb jetted on the dyno pulled 51.2 hp before I put in the yz ex cam . I have not run it after that . I should because I have done quite a few mods since then . A J.E. piston , hot cams , +1mm vavles and a ported yz head.
