Husky auto trans mod
No replies to this topic
  • Rowant
Posted 24 December 2008 - 04:16 PM
My husky is a 1987/88 430 auto and this is a clutch modification that I made to 2nd and 3rd gear to compensate for excessive wear. This works for my husky and I see no reason why it won't work for other models but I can make no guarantees as I have no experience with other models.
Because autos are now getting long in the tooth and some parts are hard to come by I used this modification to get mine working properly again. As the brass clutch shoes wear down they must, obviously, move out further to engage the drum and mine were having to move 3/8" and were always breaking their springs - often I was breaking four of the six springs after only one hours riding. The maximum operating stretch limit for the springs is about 1/4" (6mm) before they are into the danger zone so I did the following.
I measured how far the shoes were moving to engage and then had them drilled and tapped them to install small screws to reduce the travel. I then had new springs custom made with the neck extended to suit the needed dimensions.
The shoes that I am now using are locally cast and machined items because the holes in the tips of my factory shoes where the springs hook in were flogged out and very oval shaped to the point of being near to pulling all the way through. Hence the shoes in the photos are different to the factory items but do the same job.
The photos show both a standard and custom springs as well as the small screws that I used. Also you can see how the screws were positioned and how the finished item looks. My screws are just a little too close to the shoe tips but that is where the engineer put them so I will live with it.
If anybody needs any information regarding details then please don't hesitate to PM me.
  • Attached Image: pc070177.jpg
  • Attached Image: pc070180.jpg
  • Attached Image: pc070178.jpg
  • Attached Image: pc070181.jpg
