WR450F Airbox lid?
3 replies to this topic
  • Dan_Lorenze
Posted January 29, 2003 - 07:06 AM
I took my seat cover off the bike looking for the lid, all I found was a the battery covering the top of the airbox where the old lids used to be. Surely their must be a mod to get more air flow into the airbox, right?
Dan
  • SMD
Posted January 29, 2003 - 07:12 AM
Dan the twin snorkels just behind the battery slide out. They look like a sleeve.They are held in by the rivets for the battery strap clip.
Carefully pry around the rivets with a flat screw driver and pull out the snorkels.Its a little tricky but they will come out. :)
  • utvols
Posted January 29, 2003 - 07:16 AM
Dan
If you look in the opening at the top of the air box you will notice two sleaves refered to as snorkels. Remove your battery from the tray and take a screw driver and pry the two rivets on metal tab for battery strap forward until they clear the snorkel and simply pull snorkel out. This is all the modifying I have done for now. Bike seems to breath fine.
  • ThumperWR450F
Posted January 29, 2003 - 11:51 AM
i just took the snorkle out and moved up to a 155 main jet i didn't get a chance to ride it cause it is freezing rain and snow mix. i did notice that the bike idled alot better with just removing the snorkel and jetting up to a 155.
