wr 400 rattling
4 replies to this topic
  • yamaha2004r6
Posted December 21, 2008 - 07:54 AM
hi i hope some one can help :smirk: i have a 1998 wr400f which is making a clanking noise from the left side of the engine. It is quite loud and erratic and not a constant rattle you can hear it when idling standing still and when you ride it. It starts just fine and pulls really well.
Does any one any ideas many thanks.........:thumbsup:
  • Dee Perry
Posted December 21, 2008 - 07:16 PM
Check the valve clearance. Mine started doing the same thing this summer. Turned out the piston was hitting the valve. Cost me a new top end. Wiseco piston---tolerance to close!!!
  • matt4x4
Posted December 22, 2008 - 05:57 AM
Funny how both your YZ and WR have the same issue....
So which bike do you REALLY have - it could be helpful to us in diagnosing.....
Where on the left is the noise? Top, bottom, middle??
  • yamaha2004r6
Posted December 22, 2008 - 10:18 AM
i thought being more or less the same engine i would have better luck posting on both but it is a wr 400
And the noise is fo the left middle to bottom thanks
  • matt4x4
Posted December 22, 2008 - 12:33 PM
Take off the timing chain tensioner first - while you take it off, see if and how much it is pushing itself out as you loosen the screws - if it's not pushing itself out then there's a problem with the tensioner.
If it does push itself out, then the next step I would take is to remove the stator cover and look inside, could be a loose/fallen bolt (rear timing chain guide has a bolt behind flywheel.
Just wondering how many hours are on this machine and when was the last time the timing chain was replaced - could be that it's so stretched it's slapping around in there like crazy. Not a good thing.
