Crap Bent WR Plastics...
9 replies to this topic
  • Powerage
Posted December 20, 2008 - 08:22 PM
Story goes something like this, was going down into a left hand off camber corner, front washed out, i go over the right hand side of my bike, top of boot catches on left radiator cover... Below is the result :thumbsup:
Its a real pain, as now it sticks out so far that i cant lift my left leg up off the peg. Tried loosening off all the bolts and trying to refit, no good. Thought that this might have happened to someone before seeing as these plastics seem very soft that they would just bend and stretch like this. Its only my fifth ride on the bike. Maybe heating and bending will fix it? or just best to buy a new radiator cover?
Thanks guys
  • brad the best
Posted December 20, 2008 - 08:47 PM
you can try and heat it but i dont think you will fix it .
you can buy ufo plastic for about 25$ its a lot easier .
  • justbackitin
Posted December 21, 2008 - 03:11 PM
Are you sure you didn't tweek the radiator?
  • Powerage
Posted December 21, 2008 - 11:22 PM
Champion :busted: (dont know why i didnt use my head in the first place :moon: )
Just went out and had a look, and your right, the lefthand radiator brace has a definate kink in it!
It wasnt a high speed getoff, but then what would the radiator have looked like if the braces werent there.
Anyways, ill try and straighten it back out, hopefully the plastic will go back somwhat to its original spot. It is still kinked where my boot grabbed, but at least now i know why my boot got caught on it... Bent Brace!
  • matt4x4
Posted December 22, 2008 - 05:35 AM
yes - once you get your rads straight the plastic will follow - actually - you know your rads are straight if the plastic fits.
Any white spots in the plastic can be almost completely removed using a heat gun.
  • gregwr450f
Posted December 30, 2008 - 11:05 PM
Have you contacted Force?
They have great back up service and it'll well be worth a call.
  • Powerage
Posted December 30, 2008 - 11:16 PM
Nah, never went that far... simply removed the brace at the back, straightened it out with the hammer and reassembled... Pretty much as good as new.
Not bagging out the guards, but just seemed the bent a little too easy, but like i said, better than broken radiators!!
Cheers!
  • Powerage
Posted January 03, 2009 - 10:50 PM
Well, Force is going to replace the brace with a new one... What fantastic aftersales support? Its a nice thing when companys stand by their products like this.
Cheers to FORCE ACCESSORIES! :thinking:
  • Ricktc
Posted January 04, 2009 - 11:00 AM
I had the same thing happen to me when i went down 3rd gear on my wr250, same kink and everything, just had to straighten the rad mount and I was good to go.
-Rick
  • gregwr450f
Posted January 05, 2009 - 12:44 PM
:smirk: nice one!
