flywheel torque
4 replies to this topic
  • roons
Posted January 28, 2003 - 01:06 PM
All right,
Bummed out to hear of so many sheared flywheel keys!! But hey, it's supposed to be the weak link in the chain. All the load on the flywheel is supposed to be thru the taper on the flywheel/crank and the key is there primarily to time the ignition. If in fact there is an unnecessarily high load placed on this system, the keyway loses...a good thing! Where the excess force is coming from and why can't the starting system absorb this force is the question. I guarantee if there are this many cases of sheared keys, YAMAHA will figure it out.
  • xr600r
Posted January 28, 2003 - 01:16 PM
my manual has the cut and paste and says 61 lbs.
i'll be checking my nut, soon. :)
  • jwriott
Posted January 28, 2003 - 01:28 PM
I don't have a WR450 on order or anything but you mention the "keyway loses". I hope it's the key and not the keyway that is getting destroyed.
  • roons
Posted January 28, 2003 - 01:30 PM
your correct. It's the woodruff key that loses the fight, not the keyway...sorry
roons
  • law_boy
Posted January 29, 2003 - 08:22 AM
I'm unclear on what the proper torque is for the rotor nut. My manual has the cut and paste that says it should be 61 lbs (I peeled one off and the original printing said 50). However, my manual also came with a correction sheet inside the main cover that says 61 lbs is incorrect and that one should tighten the nut to 47 lbs, loosen, and retighten to 47lbs. So I guess 47 lbs is correct??
