Accelerator Pump Problem
18 replies to this topic
  • buzzfin
Posted December 15, 2008 - 09:07 PM
Went out for a ride this weekend and couldn't start my 98 YZ400. Noticed that the shaft going into the accelerator pump was not moving down into the pump when opening the throttle. I have a new pump cover and diaphram, so no problems there. If I empty the float bowl and pump cover, the shaft moves fine. When I fill the float bowl and turn the throttle, the shaft stops moving - leading me to believe the port on the carb through which the pump squirts fuel is clogged. I pulled off the float bowl and verified the pump does squirt fuel when not on the carb. Tried cleaning the port by spraying carb cleaner (no luck) and then passing fishing line, and a small piece of wire into the port on the body of the carb that the acc pump sprays into. Wire only goes in about and inch and then stops. Where does this port come out in the body of the carb? Shouldn't I be able to clear this port easily using this method?
  • divebobber
Posted December 15, 2008 - 10:43 PM
If it's the same as my 2000 426 it comes out of a little brass protrusion that sticks up maybe an eighth inch into the bottom of the carb throat. It has a hole in it on the engine side so the stream is directed into the engine.
Posted December 16, 2008 - 05:58 AM
There is a check valve to allow fuel to enter the pump housing, but not to back out, and another on the discharge side to allow fuel out, but prevent backflow. The discharge passage runs through the float bowl from the pump housing to the carb body, where, as said, it terminates in a brass discharge nozzle with the port facing the engine. If the nozzle clogs, you will almost certainly need to remove the carb to be able to clear it from the engine side.
  • buzzfin
Posted December 16, 2008 - 08:45 AM
The carb is off but I can't get anything to pass through the nozzle from the engine side. I tried carb cleaner and compressed air - neither will pass through either end and the nozzle appears to be so small there is no way I'll get wire to pass through it. Should I try a small pin or needle? I don't want to damage the nozzle by trying to shove things inside it. Any suggestions?
  • Steiny08
Posted December 16, 2008 - 08:58 AM
Try to blow from the brass side, perhapsit will come out the way it went in easier
Posted December 16, 2008 - 09:46 AM
A pin or sewing needle, used prudently, should work.
  • BC3
Posted December 16, 2008 - 11:07 AM
Maybe tiny number drills....
Posted December 16, 2008 - 11:30 AM
Number drills can be useful to clean jets with, but again, prudent use is mandatory. Be sure you only use a drill AS large as the orifice, and no larger. Just reshaping the entry/exit of the jet orifice can alter its behavior.
The hole in the end of the AP nozzle might even be smaller than a #80 drill, too.
  • buzzfin
Posted December 16, 2008 - 01:13 PM
I used a sewing needle and only the tip was small enough. Seems to have done the trick though. I can now spray carb cleaner through that passage. Putting it back together to give it a try now.
  • BC3
Posted December 16, 2008 - 01:26 PM
:thumbsup: :smirk: :smirk:
  • buzzfin
Posted December 16, 2008 - 03:44 PM
Got it all back together but it still won't start. This bike normally fires in 2 kicks. Only thing changed was adding a flexjet fuel screw. I put the stocker back in and set at 1.5 turns but no luck. I'm stumped!
  • motojoe_23
Posted December 16, 2008 - 04:41 PM
May sound like a dumb quesiton but you never know on the internet
You do have, from the bottom up, Spring/washer/o-ring right? I have seen people screw it up.
  • buzzfin
Posted December 16, 2008 - 05:50 PM
The stock screw did not have an o-ring on it, but ran fine without it. I guess the previous owner removed or lost it?? I tried the new screw with the o-ring provided (in the correct order) and had no luck, so went back to the old stock screw with just the spring, no o-ring. I just pulled the spark plug and it looked pretty bad, so I put a new one in. Still no luck. Maybe I'll try the stock screw with the washer and o-ring now that the plug is new to see if that makes any difference. If that doesn't work then I'm thinking I might have to pull the carb (again) and clean all the jets. Frustrating since I just did that a few weeks ago...
Posted December 16, 2008 - 06:22 PM
Better try again. You need the washer and O-ring. They may have stuck in the bore, though, which would help explain why you had trouble trying to install the screw with one.
  • motojoe_23
Posted December 16, 2008 - 06:50 PM
YOu may be doubling up on the washer and O-ring on accident. The o-ring will sortof "glue" the washer in frequently, and not come out. If that is the case, I bet the needle isnt sitting properly either when you bottom it out to adjust it out.
Id look closer in that area first.
  • buzzfin
Posted December 16, 2008 - 08:03 PM
I checked and confirmed the old o ring is not stuck inside. I'll put the washer and o ring on the stocker and try again. Would the missing o ring keep the bike from starting at all?
  • motojoe_23
Posted December 16, 2008 - 08:12 PM
yeah, it could. It would seriously effect the mixture at the lower RPMs I am sure. Not saying it is your only prob, but it is a prob none the less
  • buzzfin
Posted December 19, 2008 - 08:20 AM
Got out to the garage last night to work on the bike. I put the washer and spring on the stock screw, but it didn't help. Neither did fresh gas and a new spark plug. Finally figured out that the timing jumped a tooth. Not sure how that happened as the chain appears to be tight, the tensioner is in good condition and the gears appear to be okay too. The only thing I can think of is that I removed the tensioner for better access to the float bowl when I put in the aftermarket fuel screw. I'm thinking the chain must have slipped then.
  • motojoe_23
Posted December 19, 2008 - 03:46 PM
That would deffinately do it.
The only time you can safely remove the CCT and NOT risk jumping a tooth is at TDC, and even then it is recommended that you take some precautions, like zip tying the chain to the sprockets.
  • 0 replies
  • On Yesterday, 06:20 PM
  • 9 replies
  • Hot  36 replies
