7 replies to this topic
  • ham426f
Posted December 15, 2008 - 01:29 AM
header gets really bright red!! to rich lean?? car b rebuild time? any ideas
once ride it goes away, but when sits and idles it get red hot
thanks, mike
  • matt4x4
Posted December 15, 2008 - 04:33 AM
  • jhmotard
Posted December 15, 2008 - 05:24 AM
tis normal because the header is made of thin stainless steel........unless your bike is poppin and banging you shouldnt worry about it
  • ham426f
Posted December 15, 2008 - 12:44 PM
by poping and banging,, do u refer to when im letting it sit? bc it pops and bangs kinda when its cold and i have only ridden it for a short distance and then i down shift it pops and gurgles.
  • jhmotard
Posted December 15, 2008 - 09:55 PM
backfiring or bogging WHILE riding the bike....NOT revving the engine while its at a stand-still
it thats the case your jetting is a little off
  • ham426f
Posted December 15, 2008 - 11:41 PM
Is there a combination of jets that works on the 426 the best or does it just matter what the jets are now?
  • matt4x4
Posted December 16, 2008 - 07:52 AM
Since jetting is temp and altitude dependent, it's probably best to go off what you have in there now and adjust accordingly.
If it's winter where you are I wouldn't do anything to it until you're closer to your typical riding temps. Unless of course, you plan on riding it a lot in the winter.
If the bike was stroed for a length of time before you got it, it could also be as simple as a clogged or partially clogged jet making it run leaner than it should.
  • ham426f
Posted December 16, 2008 - 09:45 PM
I plan to ride a little, but this spring through fall will be the primary season for me. It runs ok, not like not running, just runs a little rough compared to how it did this summer, but that is normal for carbs i assume...?? another thing, it didn't sit to my knowlegde
