brake light problem? i think ?
1 reply to this topic
  • steviet
Posted December 14, 2008 - 03:24 PM
ive got a 2004 wr250f . the footbrake lights the back brake light up but not the front brake. is this normal. cheers guys, steve
  • doctorchopper
Posted December 15, 2008 - 10:09 AM
It all depends on if you have a pressure sensor fitted on the front brake line. WR's never came standard with pressure sensors are switches for the rear light,but they did come pre wired with a dual fillament bulb, have a look by your front master cylinder where the brake line is attatched, if it's just brake line then banjo fitting then it doesnt have a pressure sensor but if there is a small in line sensor with wires coming out then it's there but not working
