Fuel Screw O-ring
9 replies to this topic
  • Dp2boy
Posted December 13, 2008 - 12:30 PM
My aftermarket fuel screw backed out of the carb and luckily came to rest on top of the cases along with the spring. Unfortunately I can't find the o-ring. Does anyone have a pic or can you give me a description of the o-ring ? Is it a flat nylon washer or a true rubber o-ring and does it slip over the tip of the screw or seat at the bottom ? Thanks in advance.
  • Ridin Dirty
Posted December 13, 2008 - 12:42 PM
Just had my stock one out the other day. The o-ring looks like a small rubber donut that slips over the end and rests at the base of the spring.
  • Ridin Dirty
Posted December 13, 2008 - 12:47 PM
oh, and I would double check to see if it is still stuck up inside the carb. Sounds like you may have lost the washer too...
  • Dp2boy
So it just looks like a regular black "donut" O-ring that I could buy at any hardware store ?
  • Ridin Dirty
Posted December 13, 2008 - 12:55 PM
Yeah, but it is very small and your typical hardware store would probably not have it. Heres a link to a relevant thread with some dimensions: http://www.thumperta...ad.php?t=696390
  • Ridin Dirty
Posted December 13, 2008 - 12:57 PM
Copied the wrong link before. Here it is: http://www.thumperta...ad.php?t=435788
  • Dp2boy
Posted December 13, 2008 - 01:10 PM
Cool, thanks for the link. Hopefully I can find one at a local parts strore that will at least get me through the day tomorrow then I can order the correct one.
  • Chas_M
Posted December 13, 2008 - 01:20 PM
The fuel screw O-rings and washers are available at most Yamaha shops, however they list for $2 each.
Posted December 13, 2008 - 02:55 PM
Very doubtful, but here's the Yamaha part numbers:
3TJ-14562-40-00 O-RING
3TJ-14952-40-00 WASHER
3TJ-14160-40-00 COIL, SPRING
1 each
  • tdamore
Posted December 13, 2008 - 03:28 PM
There is a good chance it is still in the carb. Have you looked up into the opening yet?
  • Hot  33 replies
  • 0 replies
  • 0 reviews
  • Hot  36 replies
  • 9 replies
