Oil from Fork Bleeders
12 replies to this topic
  • almostinvincible119
Posted December 10, 2008 - 01:20 PM
I know this may be a completely stupid question, but I installed some of those Motion Pro Bleeders on my 06 450 and now everytime I bleed the forks, oil comes out with some air. I chewed up the stockers with my crap screwdriver technique. Thanks everyone
(and I know this probably should be posted in the Suspension forum, but I've searched for this problem and no one else has it, so I was wondering if it was a Yamaha thing or not)
  • DBMX 925
Posted December 10, 2008 - 01:35 PM
If you take the weight off the forks when you bleed them you shouldn't get any oil. Put it on a stand and try it..............
  • Gani_riders
Posted December 10, 2008 - 01:37 PM
the oil is sometimes coating the inside of the tubes and when the air escapes so does some oil
  • Justin89
Posted December 10, 2008 - 02:42 PM
Eaxctly...you must bleed them with the front tire elevated off the ground. If you are doing that, maybe the oring is bad that comes on the stock screws
Posted December 10, 2008 - 02:53 PM
guys, maybe I should have posted this in my original post, but I'm not that much of a noob. I dont even store my bike in my shop with the rubber on the ground.
Posted December 10, 2008 - 03:29 PM
How soon after riding do you vent the fork?
What is your outer chamber oil level?
When did you last change your fork oil?
Posted December 10, 2008 - 04:14 PM
Normally I release the air right before I ride (just once in the morning) and periodically during the week after it has been on a stand all week.
The outer chamber oil is set at stock CC's whatever that is...I think i wanna say its 350cc or something? I really cant remember without the manual
About 6 hours ago was the last time I changed seals and oil.
Posted December 10, 2008 - 07:07 PM
Both forks do this, or only one?
Posted December 11, 2008 - 08:05 AM
Both forks
Posted December 11, 2008 - 11:32 AM
You may have oil pooled on top of the free pistons, which is not a good thing. Otherwise, I have no idea. Mine don't do that.
  • Justin89
Posted December 11, 2008 - 05:32 PM
I know this may sound dumb but maybe the actual bleeders are faulty...?:thumbsup:
  • tnl
Posted December 11, 2008 - 09:49 PM
I have the same M.P. bleeders on mine and the left one burps a little too. I haven't had them serviced in a long time so I don't know why they do it but I did have heavier oil in them by the suspension shop. It stopped awhile back so maybe it was a little over filled?
  • matt4x4
Posted December 12, 2008 - 05:11 AM
Mine don't do it either even with the bike sitting on the ground since I tend to bleed them mid ride (heat makes the air inside expand so you end up building up air pressure as you ride). The bleeder really can't be faulty, it either works or doesn't, it's not like there's any part in it that is supposed to stop oil from escaping.
Sure sounds like your forks are overfilled....
  • 0 replies
  • Hot  47 replies
