Anyone had a leaky fuel cock on a yz426f
7 replies to this topic
  • britgeetarlad
Posted December 08, 2008 - 07:50 PM
mine was fine when it was in a heated garage
now its in the cold
when I turn it on....starts dripping....
is it just and o ring that forms the seal in there ?
as i have some metric gas resistant o rings
anyone know the siz
respectfully
Stephen
  • dustdogg
Posted December 08, 2008 - 10:29 PM
Mine did the same thing. It was really bad after sitting for a few months. After screwing around with it and trying to make sure the O rings were clean I finally gave up. I picked up a new complete petcock assembly at the dealer for about 20 bucks. I should have done this sooner but I figured it would have been more expensive.
  • britgeetarlad
Posted December 08, 2008 - 11:23 PM
dya know what size the o ring is lad?
that would be killer ?
Posted December 09, 2008 - 05:58 AM
There is a 3AJ-24534-00-00 seal, and a 3AJ-24523-00-00 valve packing. About 90% of the time, replacing these fails to reseal the petcock. Just replace the whole thing and save yourself some trouble.
  • tntmo
Posted December 09, 2008 - 12:10 PM
You can also replace it with a WR petcock and you will have a reserve position.
  • motojoe_23
Posted December 09, 2008 - 05:59 PM
I bought a rebuild kit for like $12. I forget the name of the company, but it came out of parts unlimeted... same company that makes a lot of carb rebuild kits. Blue cardboard backing for the envelope.
Worked fine for me. MIne wasnt leaking out around it though, it just would not turn off all the way
  • kevin nichols
Posted December 10, 2008 - 07:00 PM
My Yamaha dealer sold me the O-ring, and it was simple and cheap to replace. No big deal!!!!!!!!!!!!!!
  • DRZ04
Posted December 10, 2008 - 09:21 PM
Yamaha carries the "O" ring and the seal. You will have problems if you try to make something work cause it won't. Only a couple of bucks. Try this site you should be able to find your bike and the parts breakdown.
http://www.yamahaown...ook.com.au/?r=0
  • On January 15, 2017
  • Hot  36 replies
  • Hot  30 replies
  • Hot  47 replies
