cooling fan for wr450
25 replies to this topic
  • Summit Seeker
Posted February 24, 2009 - 06:48 AM
#21
YZ Dude, the sensor tells the fan to come on and off.
  • roushxteam199
Posted February 24, 2009 - 06:31 PM
#22
exactly by the temp of the coolant.
  • yz400fdude
Posted March 03, 2009 - 08:51 AM
#23
Well I have done some checking and it looks like that ktm kit is the best deal, then just buy another spal fan for the other side and wire them together. Mounting brackets should be easy enough. Two fans may not be necessary, one might be able to handle the job.
  • spidennis
Posted March 03, 2009 - 09:49 AM
#24
i ride alot of singletrack and bushwack. my wr used to overheat. i then bought fluidyne radiators. they are larger, more capacity, more cooling , also i use waterwetter . the bike has not boiled since. also stock jetting will run lean in the pilot jet-hot
can you fit rad guards when using the fluidyne radiators? what about the shrouds? do they need to be trimmed?
  • gravez
Posted March 03, 2009 - 01:20 PM
#25
You shouldn't need two fans I have a spal fitted to my RHS Rad and it works well ( see my other posts for pics), also on the LHS you may have trouble fitting it due to the return hose running down the back of the rad
I ride in Manila in the Philippines, 30 degrees C+ and loads of traffic and no overheat
  • roushxteam199
Posted March 03, 2009 - 07:03 PM
#26
One fan works well
