cooling fan for wr450
25 replies to this topic
  • Murray Dorward
Posted December 07, 2008 - 09:42 AM
I ride alot in the rocks and my bike overheats, has anyone fitted 12v computer fans to their radiator and if how (pictures if possible)
Muz
  • Mutu
Posted December 07, 2008 - 03:07 PM
Do a search Muzza mate, there have been people that have done it before.
I use engine ice coolant, seemed to help a fair bit.
  • jasontan
Posted January 06, 2009 - 03:39 PM
i ride alot of singletrack and bushwack. my wr used to overheat. i then bought fluidyne radiators. they are larger, more capacity, more cooling , also i use waterwetter . the bike has not boiled since. also stock jetting will run lean in the pilot jet-hot
  • phattomato
Posted January 06, 2009 - 08:13 PM
Fluidyne radiators and water wetter is the way to go. I put those radiators in my yz450f and they made a huge difference. I never overheat now. I never even look at my temp gauges any more. Unless I sit there and idle for a while in one spot. But even in slow sections I never over heat. Get those radiators....best investment!
Oh, and my father has a ktm 525 exc and they make and sell a radiator fan and thermostat switch in a kit which we bought and installed. I don't think it would bolt right up into your application but check out ktmhutt.com and look at their radiator fan kit that they sell. If you'd want to do a little fabricating, I'm sure you could some how make their fan work for your application? just a though...check it out nonetheless?!
  • roushxteam199
Posted January 07, 2009 - 04:11 PM
yes i have one on my 03. My bike is strictly for the street i used a fan from spal usa. pm me if you want to know the complete parts list and instructions.
  • yz400fdude
Posted February 20, 2009 - 07:14 PM
I have a yz not a wr but I'm interested in the cooling fan setup. I would have to run the fan off a battery though.
  • Birdy426
Posted February 20, 2009 - 09:15 PM
Muz
I've tried the 12v PC fans...they help a bit, but don't last more thn a ride or 2 off road...
  • MaxPower
Posted February 21, 2009 - 03:13 PM
[COLOR="DarkGreen"]you Sir are a hardcore WR owner. I cant thing of a more uncomforable bike for the road[/COLOR]
  • roushxteam199
Posted February 21, 2009 - 06:24 PM
its a fun bike for the road. it does vibrate a little but you get use to it. i have street tires on it which makes it so much better than knobbys.
  • yz400fdude
Posted February 21, 2009 - 08:00 PM
I'm going to take a look at the drz400 super moto radiator fan setup. I don't have a problem overheating when riding by myself but when riding with other people, especially atv people I have to sit and wait a lot. This new bike will start to spit coolant out the overflow hose in about 1-2 minutes of idling and its still pretty cool outside. I hate to think when it gets hot out.
  • nitronaf
Posted February 22, 2009 - 07:38 AM
some info on roushxteam199 install
http://www.spalusa.c...l&item=30103018
that is the fan he used
and he simply made his own brackets and manually turns it on with a switch
to be quite honest the reason why i've not bothered is simply because my fluidynes with high quality coolant has prevented me from boiling over at traffic lights on normal hotish days in australia. but a 40C day i did boil over.
heres a pic of his install
  • roushxteam199
Posted February 22, 2009 - 03:02 PM
sweet thanks for posting it for people.
  • yz400fdude
Posted February 22, 2009 - 03:19 PM
I think the fan mounting is the easy part. The problem I'm dealing with is figuring out how to make the fans work automatically. I don't want to deal with flipping a switch on and off to operate the fans.
  • Summit Seeker
Posted February 23, 2009 - 10:49 AM
You will more than likely have to install a temperature sensor on your coolant system. easiest way may be on your rad coolant line with a threaded T, Just a thought.
  • yz400fdude
Posted February 23, 2009 - 12:38 PM
I knew I would need a coolant temperature sensor, but what I don't understand is how to make the fan come on when the coolant gets to a certain temp. I was looking at the cooling fan on my atv and the fan itself seems to have a trigger on it.
  • acarter92
Posted February 23, 2009 - 04:59 PM
You need some sort of thermostat. Why not just have the fan on all the time?
Austin
  • yz400fdude
Posted February 23, 2009 - 05:06 PM
Austin
Because I don't have a WR, I have a YZ and my stator can't handle 2 fans. I will be running mine off a battery and if they are running all the time they will kill that battery quickly. I'm going to try some engine ice coolant or something first though. However, I enjoy doing things like this so I will probably go ahead for the heck of it.
  • 123BigcoopDawg576
Posted February 23, 2009 - 07:38 PM
my "cooling fan" is my right hand...twist n go faster baby :lol:
  • yz400fdude
Posted February 23, 2009 - 07:58 PM
That's not always an option when you are riding with beginners. I don't think this new bike will over heat unless its 110f and chugging over rocks but I will put it in that scenario soon enough.
  • rufusz
Posted February 23, 2009 - 11:55 PM
You need a thermostat. I've seen a kit on a KTM (aftermarket kit), and you just pushed the thermostat between the fans of the radiator (or how they are called)
