Oil Pump Questions '03 yz450
1 reply to this topic
  • chub100
Posted December 04, 2008 - 09:30 AM
I'm trying to help out a friend with an '03 yz450.
The Kicker bound up and broke the kicker shaft, somehow the idle gear that drives the oil pump also broke. I think some parts from the kicker found there way down to the oil pump gear.
How much resistance should there be to turn the oil pump by hand ?
I can turn it by hand but it takes a little bit of muscle, Is this normal ?
Thanks
Posted December 04, 2008 - 11:27 PM
No, it's not. If loosening and retightening doesn't do it, the shaft is probably bent.
  • Hot  47 replies
  • Hot  50 replies
  • Hot  36 replies
  • 9 replies
  • 10 replies
