06 Frame Same As 07?
7 replies to this topic
  • NortonMoto
Posted December 03, 2008 - 10:50 PM
I need a new frame for my 2006 yz450f And found 07 frame will it work? I do know part # is the same.
  • 426 NOOB
Posted December 03, 2008 - 11:14 PM
If the part # is the same, then it should be the same frame. There might be a difference between the two years subframe though, just check part # on those too.
Posted December 04, 2008 - 07:17 AM
Yes, it's the same.
  • NortonMoto
Posted December 04, 2008 - 12:36 PM
Thank's
  • stainless601
Posted December 04, 2008 - 01:07 PM
Not sure about the yz but WR450 in 06 used a steel frame with dry sump motor. 07 Wr450 has an aluminum frame with a wet sump crankcase-- verry different setup.
  • Kent Rathgeber
Posted December 04, 2008 - 06:56 PM
I'm curious. Why do you need a new frame?
  • TapptOut
Posted December 04, 2008 - 09:37 PM
Yeah, that must have been one hell of a crash.
Posted December 04, 2008 - 11:43 PM
The '07 WR450 is a DRY sump engine. The oil tank is locate inside the crankcases, instead of externally, but it is still separate from the sump, and the engine still has two oil pumps.
  • On January 15, 2017
  • 10 replies
  • Hot  36 replies
  • Hot  30 replies
  • 3 replies
