honda CRF250R Hard to Start
Posted 02 December 2008 - 04:14 PM
and is even pretty tricky to start cold!!!
Valves are adjusted to within .001 and double checked
Idlies Great, which is surprising.....
no Bog off the bottom
slow jet out 1 & 3/4 or 2 1/4 either is the same, running
Qstion would a Quick Shot 2 help with starting or only bog???
any other Idea's Please reply...............................
Start with choke on and one l twist of the throttle and then about 6 kicks
if your very lucky
starting hot without falling over just stoppinnd shutting the bike off
is almost impossible...........
oakley37
Posted 02 December 2008 - 05:02 PM
Sounds initially like a carb idle circuit clean is required.
Andy.
Posted 03 December 2008 - 12:52 AM
Posted 05 December 2008 - 02:27 AM
Posted 05 December 2008 - 08:12 PM
Posted 06 December 2008 - 05:55 AM
Posted 06 December 2008 - 03:53 PM
Posted 06 December 2008 - 05:32 PM
honda588 said:
lmfao i can picture someone using a blow dryer on their bike at the track:lol:
Posted 07 December 2008 - 05:56 AM
alexdog2 said:
When its 30 degrees out you have to sometimes. Believe me if you have a blow dryer or a space heater (anyone to create heat) you will have more than one person come over and and use it to try and get their bike started
Posted 06 May 2009 - 01:15 PM
The cold starting though is a big problem. I am going to try the 3 twists with choke to see if that works, and I don't really want to attemp mods to the auto decompression. I will sell the bike before I do that.
The Powerbowl did not seem to help cold starting, but it did make a huge difference with the way the bike runs and responds. I was hoping for help with cold starting though as well!
Anyway, please let me know if you get anywhere on this one...
Posted 03 March 2010 - 08:13 PM
I have tried everything with this bike (checked valves, did the de-comp mod, jetting, no gas, gas, hot-start, etc.). I give up... I am about to sell the bike and only have 6 hrs on it : (
Posted 04 March 2010 - 03:56 AM
OK after messing around with this last weekend, after a few hours of trying to start it i nearly gave up and was about to light the basturd and make an insurance claim before i can across this
this works hot and cold, hold in the hot start lever ( above clutch if your not sure) and give it a bit of throttle when your kicking it, it lets more fuel and air in so it will create a bigger bang which = easier and more chance of starting it.
Well thats my theory, get back to me on how ya go
Posted 05 March 2010 - 07:18 PM
I have found this to work better as well, but still a minimum of like 10 kicks if I am lucky
Posted 10 July 2012 - 04:21 PM
The bike is a bit dirty from my previous ride from last month I dont have a hose nearby. however I dont think that should have done anything to prevent it from starting again the carb is fully cleaned out I only rode it once after.
I will attempt a couple other techniques to kickstart the bike. I dont have any hills to crash start it. All help appreciated.
Posted 19 July 2012 - 10:04 AM
Cold = choke on, twist throttle 5 times, starts on 1-2 kicks
hot = pull hot start, find TDC then 1 kick with a slight throttle, if it doesnt start after 1 kick i hold throttle wide open with hot start and kick repeatedly until it fires, if it dont fire, then I just wait a couple minutes and repeat the process.
