Rivets Keep Busting Out of My Muffler
10 replies to this topic
  • NorCal
Posted December 01, 2008 - 02:50 PM
What are the alternatives to rivets on my muffler? The rivets closest to the engine on the
muffler keep breaking. I'm thinking screws or allen heads, but I have know idea. What
works best?
Posted December 01, 2008 - 03:24 PM
The trouble with screws is there is nothing to put threads in. You could use cage nuts (nuts with an attached spring clip), but these can cause the can to fit the front bulkhead poorly. They might work for you, though.
Try steel rivets, or go up one size.
  • MX926
Posted December 01, 2008 - 03:49 PM
Aluminum rivets vibrated out of mine, Staineless steel rivets stay in very well.
  • jrny426
Posted December 01, 2008 - 04:28 PM
Man I'm obviously not working my bike like you guys...Rivets coming out ???WOW
  • NorCal
Posted December 01, 2008 - 07:15 PM
Alright, sounds like I'm using crappy rivets then.
And yes, I ride the hell out of my YZ.:bonk:
  • 642MX
Posted December 01, 2008 - 07:40 PM
I had a similiar problem with the stock muffler on my wifes bike. I ended up putting license plate screws in it. The plate screws have a huge taper and they fit really tight, she never lost any of them.
  • zuch95701
Posted December 01, 2008 - 08:36 PM
OR you can do what i did get some 2 part epoxy and stick nuts on the back of the rivet holes and use screws and some blue lock tight.
  • buzzfin
Posted December 01, 2008 - 08:52 PM
I use hex head, self tapping sheet metal screws on mine. Seems to be holding fine.
  • Navy509
Posted December 02, 2008 - 01:17 PM
I had the same problem on the white brother exhaust w/discs. I went up a size in rivits, it worked a short while then they started to fail, the best soultion for me was to replace with a new one, I chose a FMF, it runs and sounds 10X's better.
  • 426 NOOB
Posted December 02, 2008 - 01:24 PM
I had aluminum ones fall out of my stock 426 exhaust. I used steel ones and never had another problem.
  • JYZ566
Posted December 02, 2008 - 07:14 PM
I thought this could be a sign that the packing is blowing out? Someone correct me if I'm wrong...
