'06 CRF450 high idle when hot
5 replies to this topic
  • mxvet37
Posted November 29, 2008 - 03:58 PM
This is weird. For the last couple of months my bike starts to idle really high after about 5 laps (MX) when it gets hot. It also feels like it starts to lose some snap and overall power. Some time ago, I had Tokyo Mods totally redo the carb, top end and valves and the bike was a rocket. This is a relatively new problem. I take meticulous care of it. Clean the air filter every ride, change both oils every other and change the oil filter every 4th ride. Been playing around with the fuel screw but it hasn't really helped. Any ideas? Thank you.
  • 941MXVET
Posted November 29, 2008 - 06:45 PM
If the weather has changed recently, you may require re-jeting. You should be able to turn down you idle from your idle screw located on the rider's left of the carb. If not try a different pilot jet maybe.
  • maddogyz250f
Posted November 29, 2008 - 07:56 PM
I had a YZ450 that acted like this and I never figured it out. Once the bike got warm, I just turned the idle down and it was fine. It fixed itself so I suspected some gunk in my carb or something else transient.
  • PolskaSax
Posted November 30, 2008 - 08:33 AM
My 06' does it too. I usually have to turn the idle screw down 2-3 times while riding. I havent noticed any power loss though...
  • Lilnuts
Posted November 30, 2008 - 08:38 AM
Something is either going leaner when the bike gets hot. Or it's too lean from the get go and you don't notice it until it gets hot. Try a richer pilot jet. how far out is your fuel screw? if it is more then 2 fulls turns then you could stand to richen the pilot.
And try replacing your coolant with some good stuff. Water wetter etc.
  • zZCRF450kmnZz
Posted November 30, 2008 - 08:58 PM
my buddys 03 is doing this i dont get it...
2002 crf450r..Am I wasting my money rebuilding it? by Jonridesacrf
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  47 replies
Jetting help for my popping backfiring nightmare by Budstang
  • Hot  57 replies
02 crf450r smoking after rebuild by bigg_stevee
  • Hot  43 replies
2008 CRF450r JB Weld on Crankcase by Sternzy
  • Hot  70 replies
crf450r 02 no shims in intake valves but still runs. by BreezyHonda
  • Hot  47 replies
