Carb overflow re-route
10 replies to this topic
  • _JoNeS_
Posted November 29, 2008 - 10:22 AM
I recently re routed my oil breather into the airbox, I am now about to re route my carb overflows into there as well. Just need to check which ones, ive been told its the two nearest the gear selecter in that little metal holder thing (the ones I have pointed red arrows at) if someone can let me know if these are the right ones It would be great, cheers.
  • William1
Posted November 29, 2008 - 10:56 AM
Incorrect.
The hoses attach to the carb at a "T" fitting. Take the upper hose from each side and route those. Better location is up high under the tank than the air box. Air pluses can disrupt jetting if they are in the airbox.
  • _JoNeS_
Posted November 29, 2008 - 12:33 PM
Right ok, just been reading up more, from what I understand its the upper ones I route like you said William, as these are the airlines, the lower hoses are overflows. If the airlines are submerged in water/mud this is what causes the bike to cut out, so its the two upper hoses from each side ?, I will take another better quality photo tomorrow to be safe.
  • William1
Posted November 29, 2008 - 02:56 PM
Actually, if all the hoses are submerged and/or do not not have access atmospheric pressure (also the reason venting to the airbox is not the best choice) the carb jetting 'changes'.
Posted November 29, 2008 - 04:18 PM
Only the hose that come fro the center of the float bowl is an overflow. The float level would need to be 15mm or so higher than overflow level to flow out of any of the uppers. Only the two hoses that exit vertically need be re-routed.
There is a zero possibility of that happening in a YZ air box if the hoses exit out side of the air filter.
  • _JoNeS_
Posted November 30, 2008 - 03:40 AM
Right, sorted it I think, can someone please confirm if the hoses with red arrows pointing at them are the ones I need to re route, I plan on just putting a hole in the rubber mud flap for them to pass through on the opposite side of where I ran my oil breather, would this be sufficent ? cheers
  • _JoNeS_
another
  • William1
Posted November 30, 2008 - 05:42 AM
Looks fine. I remove the black tube binding the hoses together, makes routing a bit easier.
  • _JoNeS_
Posted November 30, 2008 - 11:41 AM
Just finished up, hopefully all done right. While I was at it I insulation taped around all my conector blocks on the wiring, hopefully this will stop water causing problems, before racing I also plan to coat all electrics with WD40. Can't think of anything else that I would need to prep, if there is let me know.
Posted November 30, 2008 - 05:48 PM
I don't advise you do that.
  • William1
Posted November 30, 2008 - 06:12 PM
If you like, go to a RV store, get some dielectric grease and use that instead.
  • Hot  113 replies
  • 9 replies
  • On Yesterday, 06:20 PM
