Anyone elses from brakes squeak and squeal?
10 replies to this topic
  • WR400inOZ
Posted February 11, 2001 - 07:44 PM
:D
:D
:D
Mine have pretty much done it from day 1 of riding. Maybe its the pads..not sure..but I'm just curious to see if its normal or if others experience it? If its not normal, what can I do to stop it? (Its obviously more noticable at lower slow speeds where I can hear it over the exahust/engine)
:D
:D
  • WR400inOZ
Posted February 11, 2001 - 07:45 PM
I meant to write 'Front brakes' in the header... not 'from brakes' :)
  • Taffy
Posted February 11, 2001 - 09:44 PM
go out on it. ride it up to top speed. i mean flat out towards a wall. brake way too late.
you won't hear them squeel anymore.
i know what your thinking...
sick joke...
wrong...
your pads have polished up. your riding it like a wuss. try & melt the brakes big time.
you can even try pulling the pads out & scuffing them up with sand paper.
did you think i would really tell you to commit HK?
Taffy
  • John_in_Long_Beach
Posted February 12, 2001 - 10:14 PM
It may not be your brakes. I and several other members have had a squealing sound come from the front that sounds very much like brake squeal.
It may be lack of lubrication between the front bearing seal and the spacers. Try taking the front wheel off and lubbing the rubber seal.
This solved my squealing front end.
  • mdek
Posted February 12, 2001 - 11:43 AM
I have also had squealing from my front brake since new
  • WR400inOZ
Posted February 12, 2001 - 02:32 PM
Ahhh Taffy... very cute! Run into a brick wall, riding like a wuss.. now those are the technical and well thought out solutions im looking for!
John its definately the front brkes and not the front bearings...thanks for the thought though. I guess I'll just have to take Taffys advise and ride harder to melt in those pads. Unless someone else has any other idea's? Taffy you should write a book..."taffys quick and easy bike remedies"
  • Howard_Huge
Posted February 12, 2001 - 03:23 PM
The harder you ride them the more they squeal :) Just ask NH Kevin :D
  • mcarp
Posted February 12, 2001 - 06:52 PM
Try this:
1.) Wet sand your pads lightly
2.) Clean your disk w/ acetone or brake cleaning solvent
3.) Remove the brake pins and inspect them (rear too) If you can feel divots, replace it. You did grease this when it was new, right? :)
That should help. If it doesn't grease the bearing like John described. Couldn't hurt!
  • bonez34
Posted February 12, 2001 - 07:00 PM
Then do the WALL thing!!! :)
DRZ400E: Where's the power on this thing?
  • WR400inOZ
Posted February 15, 2001 - 03:03 AM
Thanks Howard... will give that a hurl. errmmm "You did grease this when it was new, right? " ..... nooo thats why I love this place.! Guess I will do that too. Im a bit pissed though... 2 rides and I already have a nice buckle in the front RIM!!
Im going for the BLUESTONE WALL in 5th gear
  • bart9505
Posted February 19, 2001 - 07:44 AM
I just took my wr 426 apart for the after-break-in greasing, and noticed part of the outer seal on the odometer sending unit had been folded over on installation. I cleaned the rubber dust out and put a bit of grease on the wheel seal flange, and things are much quieter.
