Safe to run in-line fuel filter on 450's?
7 replies to this topic
  • rdefonce
Posted November 25, 2008 - 07:29 AM
I want to keep dirt out'a the carb but I definitely DON'T want to starve the motor of fuel . . . which filter would you recommend for max flow, and still fit the confined space.
  • 123BigcoopDawg576
Posted November 25, 2008 - 07:45 AM
My last WR450 i ran one from new and i put over 11k miles on it with no issues what so ever...my new 08 has one on it...so i say go for it:thumbsup:
  • kain522
Posted November 25, 2008 - 07:53 AM
I hope it's safe, been doing it for 2 years. I can't remember the name of the filter (uni-flo maybe?) but the bike never seemed to lack fuel. Most of my riding has been trail with some playtime on MX tracks, so it's possible that I just haven't been on the gas enough to cause problems.
  • William1
Posted November 25, 2008 - 07:59 AM
Nearly an inline filter will be fine. You bike consumes fuel by the drop so in this case, size does not matter. If you had a steel fuel tank, full pf crap, then a large filter would be important as it would fill up junk quickly. Just keep an eye on it and when it looks like there is debris, replace it.
  • GENE426
Posted November 25, 2008 - 08:00 AM
http://www.rockymoun...ype#OtherImages
works on my CRF450 fine
  • WB450
Posted November 25, 2008 - 08:34 AM
You have a screen on your pick up tube in the tank already, but you should be ok if you want to run 2.
  • 123BigcoopDawg576
Posted November 25, 2008 - 09:05 AM
Very true but silt can get past that screen!
  • rdefonce
Posted November 25, 2008 - 09:29 AM
I concur, fine stuff can still get past that screen.
Since inline filt won't inhibit flow, I'm putting one on now.
Thanks for all your suggestions guys!
  • 5 replies
  • 9 replies
  • Hot  79 replies
  • Hot  36 replies
