16T Counter.. will it fit?
7 replies to this topic
  • stev0
Posted November 25, 2008 - 12:31 AM
will help topend alot.. will a 16t go in?
15t just about fits...
  • MarshalGiles
Posted November 25, 2008 - 06:29 AM
The 15 is really close on mine, and the chain actually rubbed a bit on the case guard initially, so I really doubt a 16 would fit. Is there even a manufacturer that makes one for the WR450?
  • stev0
Posted November 25, 2008 - 06:43 AM
Not sure, but im sure one can have a 16t custom made.
Spoke to my local race shop and he reckons it wont go on.. i just thought its alot cheaper to change the front then the rear... its also so much easier then taking the whole back wheel off.
  • MaxPower
Posted November 25, 2008 - 08:34 AM
[COLOR="Green"]I had one on my 04 WR450.You have to remove the cheesy case guard .The chain is real close to the case but it clears.
I think I still have it somewhere if you want it. It used it for less than 100 miles[/COLOR]
  • justbackitin
Posted November 25, 2008 - 11:41 AM
I have a 16T on mine. I think its a sun star. I had to remove a small amount of material off of the case guard to make sure there was some clearance on the chain. Other than that it has worked fine all of last season. I run my wr on the street so it's perfect for me.
  • LILBIT
Posted November 25, 2008 - 05:00 PM
I saw posts of a few of the SM guys running a 16t. Like stated above you have to grind a little slider pad out of the way.
  • MarshalGiles
Posted November 26, 2008 - 05:55 AM
So where did you guys get your 16t sprocket?
Edit: Looks like a JT 16t sprocket can be had from the Parts Unlimited catalog for $10.95.
  • MaxPower
Posted November 26, 2008 - 07:21 AM
[COLOR="Green"]I think mine said Sunstar on the side of it[/COLOR]
