Where can you buy Toluene for a HC piston?
10 replies to this topic
  • Justin89
Posted November 24, 2008 - 08:51 PM
:bonk: Hey guys, where can you buy the fuel addative toluene? I heard you can mix this with regular supreme gas for a higher octane...is this true? Will this hurt/is it bad for the bike in any way? I'm just thinking about putting a 13:5:1 piston in my Yami and dont want any pinging going on. Also, can you just use a car octane booster for this type of stuff? Sorry for all the questions and thanks in advance.:bonk: :bonk:
  • ncmountainman
Posted November 24, 2008 - 09:43 PM
sherwin williams, mix 20% toluene (1 gal toluene,4 gal gasoline) may need to lean out your jetting a little.
car octane boosters are crap,there is one brand left that is actually real lead additive;i think its called octane supreme.:bonk:
  • Justin89
Posted November 24, 2008 - 09:49 PM
Thanks for the info on the toluene! Im just worried about some pinging going on and dont want to run race gas...
  • krzyaszwhiteboy
Posted November 25, 2008 - 08:02 AM
You can buy it at any Paint Store. I would sugest staying away from Sherwin Williams in CA. Be prepared to show your ID. It is now illegal to sell toluene in CA without checking ID. Try Vista Paint....probably the best price, then Frazee, ICI, Dunn Edwards and lastly SW.
Posted November 25, 2008 - 09:24 AM
And why?
  • Justin89
Posted November 25, 2008 - 10:11 AM
And why?
Hey gray, what do you think about this toluene as an octain booster? So auto octain boosters are crap then right? :bonk:
Posted November 25, 2008 - 11:30 AM
Toluene is pretty effective, and was a major component of some of the better non-lead boosters. It's also already a component of gasoline (especially race gas), so it's not voodoo chemistry.
Auto octane boosters aren't crap, exactly, but they do tend to be somewhat over rated. When the label tells you that it will raise the octane 3 points, that means it will take it from 91 to 91.3, not to 94.
  • qwik12beat
Posted November 25, 2008 - 04:48 PM
I have used toluene in my car quite a few times. Without it i could only run 24psi with less than 5 counts of knock.When i add 2 gallons toluene to about 10gallons of 93 i can run 30+psi with no knock at all.:bonk: E85 is even more knock friendly, but it only has about 70-80% the power potential gasoline does. This is why you have to burn so much more e85 than gas. E85 wouldnt be a practical fuel for a bike. Sorry i started to ramble there:smirk:
Over time it can damage fuel pumps, and seals. It would take alot though
  • krzyaszwhiteboy
Posted November 26, 2008 - 06:55 AM
And why?
Because they have raised there price on solvents 4 or it might be 5 times this year alone. They are just way over priced would be my main reason. There are other issues with many of there products but that would be wayyyyyyyy off topic.
  • ncmountainman
Posted November 26, 2008 - 07:34 AM
if you buy it in case form(4 /1 gal cans) its $12 a gal here,if ya work that out its about $4 a gallon for your own race gas;i also add a capful of marvel mystery oil to the 5 gal can as the toluene is a bit dry.
Posted November 26, 2008 - 09:01 AM
Bob,
You mentioned finding the need to lean the jetting. Others have posted the opposite. What was your experience with it at 20%?
  • Hot  113 replies
  • Hot  47 replies
  • Hot  50 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
