Jetting D-Base for CRF250R
19 replies to this topic
  • RallyImprezive
Posted November 24, 2008 - 07:51 AM
A thread like this exists over in the YZ/WR 250F forum, and I thought it would be nice to have one here. Here is the template:
Model Year:
Main jet:
Pilot Jet:
Leak Jet:
Fuel screw (turns out):
Needle model/Clip position:
Airbox mods:
Pipe:
Altitude where you ride:
Temperature where you ride:
Other mods:
Degree of satisfaction:
Try not to fill the thread with other topics. Jetting questions should probably be directed to the Jetting forum. This will help make jetting searches more productive. So go ahead and post your specs!!
Mod: Sticky?
  • RallyImprezive
Posted November 24, 2008 - 07:55 AM
Model Year: 2008
Main jet: 178
Pilot Jet: 48
Leak Jet: Stock
Fuel screw (turns out): 2 Turns
Needle model/Clip position: stock needle, 3rd position
Airbox mods: None
Pipe: Stock
Altitude where you ride: 6000'
Temperature where you ride: 50-60F
Other mods: None
Degree of satisfaction: Bike starts far more easy than stock. But there is some bog with the first 1/4 throttle turn. Pulls very hard and strong above 1/4 turn on the throttle.
  • nzmech
Posted November 24, 2008 - 11:39 AM
09,jd jet kit 190 main red needle 5th clip,42 pilot,55 leak,1 3/4 turns out, 8thou ex,4thou in,no other mods,20-30 deg C, 0-2000 feet, Runs & pulls clean, no starting probs A++ NO bog whatsoeva!
  • moto-101
Posted December 10, 2008 - 04:45 PM
What to do with my 08 crf250r i just instaled a merge racing leak jet and a jd jetting kit i have way to much bog on the bottom end, im using the red needle the clip is on the 4th position and a 190 main and im riding at sea level in vancouver canada, all the other jets are stock
  • seth240
Posted December 10, 2008 - 04:57 PM
Model Year:2007
Main jet:172
Pilot Jet:42
Leak Jet:45
Fuel screw (turns out):2 1/4
Needle model/Clip position:3rd
Airbox mods:none
Pipe:stock
Altitude where you ride:0-1000
Temperature where you ride:50-70
Other mods:removed baffle plate in float bowl, turned ap timing screw 2 1/2 turns in
Degree of satisfaction:Very high :thumbsup: no bog at all!
  • shlambd
Posted December 10, 2008 - 11:49 PM
did you not read what the first post said?
  • moto-101
Posted December 11, 2008 - 08:49 AM
sorry im new at this yes i did read the first add thanks!
  • 22wdad
Posted November 10, 2009 - 02:12 PM
Model Year: 2008
Main jet: 168 winter, 162 summer
Pilot Jet: 40
Leak Jet: 40
Fuel screw (turns out): 1.5 to 2.25 Turns
Airbox mods: None
Pipe: Stock
Altitude where you ride: 4,000+ ft.
Temperature where you ride: 35-105F
Other mods: None
Degree of satisfaction: Starts good hot or cold and pulls hard, but I'm still looking for the right needle...
  • chayes627
Posted November 10, 2009 - 03:35 PM
Model Year:2007
Main jet:175
Pilot Jet:42
Leak Jet:65
Airbox mods:none
Pipe:stock
Altitude where you ride:0-2000
Temperature where you ride:50-80
Other mods:Boyeseen QS2
Degree of satisfaction:no bog at all
  • dirtracker
Posted February 03, 2010 - 01:41 PM
Model Year: 2006 CRF250R
Main jet:[ 172 stock] 170
Pilot Jet:[40 stock] 45
Leak Jet:[55 stock] 50
Fuel screw (turns out):[1-3/4 stock] 1-1/2
Needle model/Clip position:[NHFS 3rd clip] stock
Carb mods: float bowl baffle remove,Merge racing AP spring
Airbox mods:stock w/ twin air filter
Fuel: pump gas
Pipe:White brothers dual aluminum
Temperature where you ride: 50-80 F
Other mods: Hotcam stage 2
No bog whatsoever very crisp sharp throttle response pulls clean from bottom to top.Starts 1st or 2nd kick most of the time.
Edited by dirtracker, February 07, 2010 - 07:10 PM.
  • Charlie C
Posted February 03, 2010 - 02:32 PM
What size pilot is in it to start with? I can't remember which adjustable leak jet says to remove the leak jet completely. It might be the merge. I don't know much about the JD jetting kit, but the 190 is really rich. I can get them to run real strong without the JD jetting kit and just playing with the stock set up with the addition of the adjustable leak jet. How far in do you have the screw turned in on the adj leak jet? I know on my kids 08, it's almost all the way in. His has the R&D adjustable leak jet with a 42 pilot and a 172 main. Needle in the 3rd position and who knows how far the mixture screw is out. It runs hard!
Also, is there any other work done to it like head porting?
  • homernukem
Posted February 06, 2012 - 04:05 AM
Here's a site that has stock crf250's and crf250x's it shows stock jetting and has several jetting charts.
http://rickramsey.net/CRF250X.htm
  • BassMan
Posted February 20, 2012 - 06:08 AM
Model Year: 2008
Main jet: 172
Pilot Jet: 45
Leak Jet: 40
Fuel screw (turns out): 1 Turn winter 1/2 turn summer
Airbox mods: None
Pipe: FMF Q
Altitude where you ride: 600'
Temperature where you ride: 30-100+F
Other mods: Rekluse EXP 2.0
Degree of satisfaction: easy starts cold or hot, runs great
  • slidin
Posted February 20, 2012 - 06:23 AM
Model Year:2007
Main jet:172
Pilot Jet:42
Leak Jet:45
Airbox mods:none
Pipe:stock
Degree of satisfaction:Very high :bonk: no bog at all!
Same, same. No bog/exact setting
  • Keith72
Posted February 20, 2012 - 04:07 PM
Model Year: 2009
Main jet: 172 winter, 168 summer
Pilot Jet: 42 winter, 38 summer
Leak Jet: 70
Fuel screw (turns out): 2.25
Needle model/Clip position: NLCT / 3rd from top
Airbox mods: None backfire screen not removed
Pipe: FMF 4.1 with megabomb
Altitude where you ride: 1000' approx
Temperature where you ride: 35-105 degrees
Other mods: ported head, 37mm carb bored to 38.5
Degree of satisfaction: starts and runs great no bogs
  • Goforaride
Posted March 17, 2014 - 12:04 AM
Bump
  • tomjv
Posted May 30, 2014 - 02:24 PM
2006 CRF250r
176 main
45 pilot
NKBT needle on 3rd clip from bottom (of 5)
100-2500', 60-90 deg F
Mostly stock.  Bike runs fine.
TomJV
Edited by tomjv, May 31, 2014 - 09:56 AM.
  • tonyiaco290
Posted May 30, 2014 - 06:29 PM
Model Year: 2005
Main jeticon1.png: 172
Pilot Jet: 45
Leak Jet: stock
Needle model/Clip position: stock/3rd
Airbox mods: No Toil filter cage
Pipe: stock
Altitude where you ride: 800-3500
Temperature where you ride: 60-85
Other mods: 2008 higher comp piston
Degreeicon1.png of satisfaction: Very Good
  • FCR Expert
Posted September 07, 2014 - 01:03 AM
2007 CRF250R
Main: 178
Pilot: 42
Leak: 50
Fuel: 2 1/4
AP timed to squirt just as throttle plate clears the stream.
Stock compression, stock exhaust (fresh repack), stock intake, Twin Air filter. Stock valves, set correctly.
Elevation 750 meters, Temperature avg 10-20 degrees C. Alberta, Canada
Varying terrain. Bush roads, single track, prairie, mountains, sand, dirt, hard pack.
This bike had a severe lean bog issue. Would flame out if you twisted the throttle any amount from low RPM or idle if it wasn't done relatively slowly. Cleaned carb, checked seals and AP diaphragm, all ok. Had to dig deeper.
Since tuning the AP timing and leak jet the bog is completely gone. Squirt duration of the AP on the bench was .10 seconds with stock #70 leak jet and started too late. Duration is now .25 seconds with #50 leak jet and starts as soon as throttle plate clears the stream.
Smooth acceleration, pulls strong through RPM range. Slight popping on deceleration from high RPM's. Rides well in all terrain.
Header pipe does not glow when sitting and idling.
Edited by techgreg, September 07, 2014 - 01:20 AM.
  • Double R Rippin
Posted July 11, 2015 - 11:42 AM
Model Year:2007
Main jet:172
Pilot Jet:42
Leak Jet:45
Airbox mods:none
Pipe:stock
Degree of satisfaction:Very high http://www.thumperta...R#/thumbsup.gif no bog at all!
I did this same setup on my 2007 crf250r and I experienced no bog at all, absolutely stoked about this, thanks seth240
Should I get a two stroke? by Daniel_Likes_Bikes
  • Hot  95 replies
Honda CRF250R 2017 by Chris.GVS
Honda CRF250R 2017
  • 0 reviews
Honda CRF250R 2016 by zing
Honda CRF250R 2016
  • 5 reviews
  • Last review by Mark Matthews
  • On January 08, 2017
Steam/white smoke coming out of crf250r by Seth McKenzie
Dirt Bike   Make / Model Specific   Honda   CRF250R
Crf250r starting help by Mghonda
  • Hot  48 replies
