Replacing WR subframe with a YZ subframe????
2 replies to this topic
  • dangler
Posted January 22, 2003 - 06:01 AM
For those of you who have done this....The YZ and WR subframe are identical , except the YZ is aluminum and it doesn't have the extra mounting tab for the radiator overflow canister, correct? What about the side panels & airbox? They are the same too correct? Does anything else need to be changed when changing the subframes to get everything to fit correctly?
  • charlieb
Posted January 22, 2003 - 07:59 AM
I do know the side panels are different. The 03 WR has a quick change acess panel for the air filter on the left side.
  • jmiakaike
Posted January 22, 2003 - 10:30 AM
should work fine..
i have a '99 yz 400 frame, '00 engine, '01 plastic, shock and subframe.
