changing wr timing
2 replies to this topic
  • Bambislayer
Posted January 21, 2003 - 05:19 PM
how hard is it to change a wr to yz timing and how does the change improve performance?
  • jeff_eugene_or
Posted January 21, 2003 - 05:48 PM
It takes about one hour and is pretty easy. Make sure you have clear instructions on how to do it. I got mine from Baja Designs. The throttle response was better and it eliminated the hesitation from off-idle. A very worth while job.
  • Dodger
Posted January 21, 2003 - 05:59 PM
Very worth while!! Just make sure you've got access to a good torque wrench, make all the difference when re-torqueing the camb bolts. It was literely the difference between valves within spec, vs. too loose/tight.
Dodger :D :)
