08 YZ450F Silencer
9 replies to this topic
  • racerdale
Posted November 20, 2008 - 06:53 PM
Has anyone done any modifying to the stock silencer on the 08 450s? If so,did you have to do any jetting changes.My bike seems to have alot less power compared to friends 450s and they have aftermarket exhaust.The stock exhaust is very much blocked.Thanks for any help.
Posted November 20, 2008 - 06:59 PM
Not that I know of, and I don't recommend doing anything other than replacing it. You're free to try, though.
Almost anything you put on it will increase the mid range power significantly.
  • erickdj
Posted November 21, 2008 - 09:16 AM
A two hp increase isn't much. Virtually any competition exhaust installed on the '08 will add 4 or more (some of them much more) at or around 5000 rpm. :thumbsup:
how many horses does the Dr.D add @ 5k RPM?
Posted November 21, 2008 - 10:01 AM
I've only ever seen one chart from an '08 with a DRD on it, but that one showed a gain of 6 at 4800, and a loss of 0.25 at peak. The caveat was that there was no effort made to optimize the bike with the stock exhaust. Then again, not much was done to the bike after the DRD was bolted on, either. Just some minor jetting.
  • erickdj
Posted November 21, 2008 - 10:04 AM
wow, 6hp is pretty significant. What optimizations or adjustments would you recommend to go along with the Dr.D?
Posted November 21, 2008 - 10:35 AM
Something along these lines:
http://www.thumperta...785#post7029785
http://www.thumperta...050#post5380050
  • erickdj
Posted November 21, 2008 - 11:52 PM
is it just me, or did some posts disappear from this thread? including one with a dyno chart...
  • mx614
Posted November 30, 2008 - 05:05 PM
Yes I removed the last cone before it exits and cut the remaing non perfed part out flush, leaving the first cone in place. jetting is stock main and a 48 pilot with the fuel screw on 2.25 out. I have now sold my DR.D in favor of this set up. Good smooth power and still way quieter than my DR.D was at 99db, this one moded is at 97. I hope this helps.
  • gtxkid
Posted November 30, 2008 - 05:37 PM
Mine added 4-5 hp with the DR.D and a 13-75-1 piston.
I went to CA for a race and Air Fuel was 11.8 to 11.9 and i thig they shoot for 12.0, But that is real real close.
Guy that gave us a tour from Pro circut still beat me.
Made the bike harder to ride, but if you want power it works.
  • racerdale
Posted December 01, 2008 - 09:06 AM
so you took the long cone out flush with the rear of the silencer?Thanks for your input!
