Hard to get carb!!
9 replies to this topic
  • siscokid7
Posted November 20, 2008 - 01:33 PM
Does anyone have any tips/tricks for working on the carb of an 08 yz450? I installed an MSR fuel screw and my fingers look like a monkey paw! Now I gotta rejet for the weather and I am not looking forward to it. Any suggestions? Also I tried turning it sideways off the intake boot but the motor mounts prevent it from spinning more than an inch.
Posted November 20, 2008 - 01:48 PM
The motor mounts need to come off if you want to rotate the carb. It's not that hard.
If you want to remove the carb, remove the sub frame first, then unbolt the shock (that sounds like a lot of work, but it's not that hard either). A very helpful tip for reassembly is to take the air box off the sub frame (4 bolts) and clamp it onto the carb first. Then install the shock, then the sub. Tremendous reduction in the hassle factor.
But just for jetting, you can leave everything right where it is. As long as the needle jet stays screwed into the carb, everything will be OK.
http://www.thumperta...ad.php?t=556427
  • FLeX484
Posted November 21, 2008 - 09:35 AM
Get a motion pro or thumpertalk quick change jetting tool and a small dental mirror. Now i can change the pilot or main jet in about 5 - 10 minutes :thumbsup:
Posted November 21, 2008 - 10:18 AM
Like this one, from the link I posted?
http://www.thumperta...687#post5325687
  • FLeX484
Posted November 21, 2008 - 11:07 AM
sorry......didn't even click on the link.
Posted November 21, 2008 - 02:06 PM
I bought one of them a while back. Did you find that the rubber didn't stay on the thumb wheel?
  • FLeX484
Posted November 21, 2008 - 03:03 PM
Yep, I have the motion pro one, and the rubber fell off first use. Still gets the job done, but it does annoy me.
Posted November 21, 2008 - 03:32 PM
I ground 6 half round notches into the OD of the wheel so it has flutes in it, makes it easier to get a grip on. :thumbsup:
  • William1
Posted November 21, 2008 - 04:41 PM
I use the Motion Pro 90 degree tool. Pricey but makes jetting changes a breeze as well as tweaking the AP timing screw.
http://www.motionpro..._4__hex_driver/
  • mywifefarts
Posted November 28, 2008 - 11:42 AM
I agree!:bonk:
Motocross
  • Hot  491 replies
  • 0 replies
  • Hot  50 replies
  • On Yesterday, 06:20 PM
