Engine Idle
2 replies to this topic
  • F6dood
Posted January 20, 2003 - 06:32 PM
426 Engine idles great when cold. After warm up, engine idles high, maybe 2500 - 3000. If I drag engine speed to normal idle w/ load it will normal idle until throttle change then goes back to high idle. Opened pilot needle up 1 turn and symptoms some better. My guess is that pilot jet too small & mixture too lean after warm up. Anyone had experience w/ this?
  • dominator426
Posted January 23, 2003 - 08:41 PM
Yeah, that's right...I only needed to open the PFS about 1/4 to 1/2 turn more than 1 1/8 turn for colder weather, along with a larger MFJ.
  • r1superstar
Posted January 25, 2003 - 06:24 AM
Yes, this is correct. Adjust the Air/Fuel Mixture screw and you should be fine. Also check to make sure your throttle cable is not too tight (just in case).
