08+ KTM Cam Chain Tensioner Upgrade/Fix
24 replies to this topic
  • Bryan Bosch
Posted November 18, 2008 - 02:38 PM
http://shop.thumpert...ricks_tct-1.htm
  • XR_Dude
Posted January 12, 2009 - 06:59 AM
How do you install it?
  • veloc1ty
Posted January 12, 2009 - 12:53 PM
Here's the company website - http://www.dirttrick...n_tensioner.htm
and the installation instructions - http://www.dirttrick...ctions_rev1.pdf
There's also a thread in this sub forum discussing the cam chain tensioner.
  • VilleKTM
Posted January 13, 2009 - 03:18 AM
Go check the link Velo provided. Installation is fairly easy jobb. Done in 5-10 minutes.
  • mxdad59
Posted January 20, 2009 - 02:30 PM
Hey Ville,
Do you need to TDC the motor or not on the new motors?
Thankx
  • VilleKTM
Posted January 20, 2009 - 02:38 PM
Nope. Just pull out the stock tensioner but be careful with the o-ring so you don´t drop it inside the engine. Install the DT tensioner according the description that followed it.
  • pauljas
Posted February 06, 2009 - 01:24 PM
You still need to put the crank in TDC. This is because there could be tension on the chain caused by the valve springs etc.
I still think this solution isn’t sufficient because it still uses spring power. The proper solution I think is the mechanical chain tensioner we use here in Holland, manufactured by mxgadgets
  • VilleKTM
Posted February 08, 2009 - 11:14 AM
No you don´t. Not on the SXF engine.
  • Eli_Westrup
Posted February 22, 2009 - 08:14 PM
Im confused, i have an 07 250 sx-f, will this work? In one sentence it says it will but my bike is on the list of bikes that it will not work for.
  • KaptainKoolz
Posted February 22, 2009 - 09:16 PM
does it say that on the DT web-site? or the TT parts store? i ordered from the DT site for my 06 250 and got exactly what i needed...quickly..and it works great! , thumbsup to nate at dirt tricks ! :lol: :worthy:
  • VilleKTM
Posted February 23, 2009 - 03:55 AM
+1 for Nate ! A nice guy.
  • Eli_Westrup
Posted February 23, 2009 - 06:12 PM
Yeah the Dirt trick website, but i guess it works since you have one for your '06
  • petecawson
Posted April 21, 2009 - 09:24 AM
hi im new to the ktm world does anyoneknow if i can get such a thing for my 2006 sxf250??
any help would be great
thanx
  • VilleKTM
Posted April 23, 2009 - 10:19 PM
Yes ,you can. Mail / call Dirt Tricks.
  • albertaguy
Posted May 15, 2009 - 06:46 PM
put mine in last week, less engine/chain rattle on sudden decel for sure
  • Flyin Ryan
Posted September 09, 2009 - 05:52 AM
Go to the source..........call Nate at Dirt Tricks 775-267-6361
  • otter101
Posted October 03, 2009 - 05:10 PM
So my 07 250 xcwf has been making a horriable noise when you try to start it both with the e and kick. The sound, sounds like it comes at the bottom of the stoke but unsure. I have checked the valves twice back to back and they check out ok. They bike has been becoming harder and hadrer to start both hot and cold but once running it seems to be fine. So I started thinking cam chain tensioner ( the noise is not heard at all while running) I took the one out of my 08 250 xc-f and put it in the 07 the noise is the same. So I put it back in the 08 and now the 08 sounds horriable just like the before video of the upgrade video. So what did I do wrong in putting the 08 back in I did notice that when I put it back in it was compressed and should I have put the motor to TDC And if so how do I set that with out pulling the valve cover off and lining up the makes.
  • PhillyMac
Posted October 21, 2009 - 06:33 AM
I am actually wanting to install this on my 08 250XC-F. i am reading where some say to set it at TDC and some saying the opposite. Do you have to set motor to TDC on the 08 XC-F?
  • KaptainKoolz
Posted October 21, 2009 - 06:41 AM
shouldnt matter as long as you install the tensioner right, just make sure you double check the tension after you tighten down the CCT cap:banana:
  • kx137
Posted July 02, 2010 - 06:31 PM
I have an 08 ktm 450sx-f. I purchased and installed dirt tricks cam chain tensioner. I installed it with the machined "TOP" side up. The instructions state that you should hear the clicking when placing the spring in, I did not. I uninstalled everything and tried again placing the "TOP" side down b/c it only seemed to ratchet this way when not in the engine. When I installed it like this once again no clicking. I uninstalled and reinstalled once more this time pressing on the plunger with a small punch lightly ... I think i may have heard one click. I got an email out to dirt tricks, What do you guys think is it defective? Thanks
Solution : spoke with dirt tricks and several others, no worries about the non-clicking due to chain still being tight / new.
Edited by kx137, July 09, 2010 - 07:29 PM.
SXF 350 big bore kit by Steve_Kay
  • Hot  31 replies
What brake fluid to use by Rageodontist
  • 2 replies
Washington
KTM Discontinued the xcf-w line up for 2017, now what?! by jasongind
  • Hot  28 replies
Transmission swap? by jake101
KTM 350 SX-F 2016 by Toby259
KTM 350 SX-F 2016
  • 6 reviews
  • Last review by PALIKUL
  • On March 16, 2016
