Fork Rebuild Procedure
3 replies to this topic
  • Dude
Posted January 20, 2003 - 12:02 PM
When replacing the fork seals, do you need to pull and clean the dampner or can you just do the seals?
  • Wicked_Crash
Posted January 20, 2003 - 12:12 PM
You can just do the seals, you do not need to pull the damper rod. It is a fairly simple procedure, just take your time when disasembling and if you don't have a manual, use the other fork as a reference guide. While you have the forks off, get a set of seal savers.
  • Dude
Posted January 20, 2003 - 01:41 PM
Do I need to replace the slide metal and piston metal bushings, or can I get away with the seals only?
  • Wicked_Crash
Posted January 20, 2003 - 01:44 PM
You shouldn't have to replace the bushings unless they are worn. Also, replace the dust seals and oil seals as a set.
